Hey guys
Please help, yes ive read every page that has somthing to do with 02 sensors on this site.
This is my situation
On my Cefiro, i pulled off the dump heat shield and left it off. This caused the WIRE AND PLUG for the 02 sensor to be melted to pieces. The whole loom was roasted as well, leaving only about 10 cm of loom near the chassis.
I have ordered a new 02 sensor alredy picking it up this afternoon and ive got a 3 pin connector as well.
Now my problem is.
What sort of wire can I use to extend the 3 wire loom, what is the sort of Heat proof coating I put over it and also lastly
HOW THE HELL CAN I REMOVE THE 02 SENSOR? I can get a Open ended 22 over it, I can get plenty of leverage, AND ive even Soaked it in Rost Off (angriest version of WD40/Penetrene) and used all my strength but the thing wont budge.
Am I just weak or is there another way - I cant get hold of a 02 socket (Repco/autobarn/supercheap) dont have one - so any other suggestions?
Hope you guys can help
Regards
Kim
https://www.sau.com.au/forums/topic/143077-urgent-help/
most exaust shops will have a nut that you can weld onto ya manifold for ya 02 sensor . try heating ta old one up with a oxy if ya have one or try putting a pipe on ya spanner for more leavearge
https://www.sau.com.au/forums/topic/143077-urgent-help/#findComment-2666033
it's not easy getting off.. you can run the car without the o2 sensor for a while if you need to. Maybe try undoing it when the dump is warm. Obviously not fuse-the-fingers hot, but once it's started to cool down to touchable levels.
just zip-tie the o2 plug to the firewall, will stop it flopping down and melting in the future. That seems to have worked for me. If you want to insulate it (say if you run at regular full boost levels), I'd use some of the stuff you use to insulate turbo lines.
https://www.sau.com.au/forums/topic/143077-urgent-help/#findComment-2666519
Maybe have to take the dump off to get enough leverage? that's what I had to do with my original dump pipe to get it off as a last resort.
where would you buy insulative stuff, gordo?
will places like supercheap have that?
Try Revolution racegear, there is one in moorooka in bris..
http://www.revolutionracegear.com.au/?fa=R...6332E944FB94049
Either that or a specialist hose shop may have it to insulate fuel lines, etc.
https://www.sau.com.au/forums/topic/143077-urgent-help/#findComment-2667268
Had the same problem before... surely it was a biatch to take off. O2 sensor wrench was way too expensive ($45 for a socket... forget it).
So, went to Bunnings to the plumbing section, got some sort of wrench for plumbing / piping, octangular in shape, fits perfectly. Used a long stainless steel rod along the wrench for leverage, and half a can of WD40 later... hurrah!
I hope that helps..
DD
https://www.sau.com.au/forums/topic/143077-urgent-help/#findComment-2667805
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
