ok done some research in comp ratios confused teh hell out of me, plus i dont know of the figures needed for my engine. so could someone tell me what comp ratio i would get if i used a 1.5mm head gasket on an rb25det r33 which has 1:standard pistons 2: 0.02" over sized pistons?
both with using the standard head/ valves ect (for convience use std values even tho heads gona get ported)
would this gasket be too big? comp ratio too low?
application is street, 400-430rwhp, pump fuel (ultimate)
what are pros and cons of a slighly lower and slightly higher comp ratio than std?
Edited by humz
https://www.sau.com.au/forums/topic/143107-comp-ratio-question/
benefits of higher comp will be
Quicker boost (reduced lag)
More hp can be made with less boost
Bad stuff
Less timing
can cause pinging more (up to tuner)
have to maintain real high octane fuel(due to static comp Rise)
and what comp pistons do you have
MR331307- well im actually tryna buy your arais pistons lol i msged ya just now but no reply as yet :D either that or some other piston on the forums will definately be bought soon.
r33_racer- excatly what i wntd to know, thanx!
is a 8.5:1CR quiet low, or within normal cr range?
what would be teh limits of CR? both uper and lower limits? obviously it depends on many factors, but lets stick with safe, street power.
8.5:1 is what RB26's run. RB25's run 9:1.
It wont be that if you go 20 thou over though. More like 8.6 I think.
For your power level the higher the better but it's safer to stay low. What turbo are you using?
I'm running 8.75:1 and getting 260 odd rwkw.
Generally you need to increase boost by between 0.1 and 0.2 bar for every 0.1:1 drop in CR to maintain the same power.
C/R will INCREASE if you bore for, and fit, bigger pistons, because you are increasing the swept volume. But I doubt the increase will be significant (more than 0.1) for a 20 thou O/S.
By fitting a thicker gasket, you are effectively enlarging the combustion chamber, so the C/R will drop.
actually isnt std bore size 86mm i believe 86.5mm is first oversize(20 thou over).
Im pretty sure i veryneared (verniered )measure the rb30 bore before we got it opened up for the new CPs and it was spot on 86mm. As 87mm is final oversize i think.
Wait. When did this engine become a 25/30?
86mm is standard bore size for RB25, RB26 and RB30. I think you can take them out to 88 without sleeving but don't quote me on that.
You use the right size gasket for the bores you have.
Personally I'd rather keep the static CR up around 9:1 because mega boost pressure is not everything . IMO thicker head gaskets are a poor way to decrease CR particularly if the engine is being built up and you have some say in piston type . Lifting the head higher off the piston crown will increase the chamber volume but its not ideal around the quench or squish zones so may not be any more detonation resistant . The higher 9:1 with the 100 oct Shell pump fuel should work out well enough . Having low CR and high boost would be ok if the engine lived in a boosted environment all the time but they dont , and they do feel like a soggy breathless boat anchor off boost because of the low dynamic compression pressure .
High boost pressure does not always guarantee high airflow , far better to remove where possible the resistance to flow to get a greater weight or mass of air into the chambers . Doing this with less boost also means lower fuel pressure requirement/less energy to recover from exhaust gass (meaning less resistance to flow through turbine/housing) / ignition timing optimised around burning efficiency rather than detonation supression .
My 2 cents spent for today , cheers A .
I increased my compression ratio to 8.8:1 on my GTR rebuild. I run it on our piss water 95 Octane here in NZ with no problems on 18psi, with tuning to suit of course. It makes 285 RWkw on a dyno dynamics 2WD dyno.
Lag is not in my vocabulary. Comes up on to boost like a bloody rocket ship and I contribute the higher comp ratio for this when compared to other GTR's I have driven.
Mike
    • We're back on, gang - Our yearly pilgrimage south to our favourite cafe for an awesome brekkie! Yes, that's right... we're heading down to Austi Beach Cafe for a breakfast run through the Royal National Park! Before you drool over your phones/keyboards, here are the details: Date: Sunday 23rd February Meet Location: Loftus Oval Carpark, Royal National Park, Sutherland Meet Time: Meet at 7:00am for a 7:30am departure Destination: Austi Beach Cafe, 104 Lawrence Hargrave Drive, Austinmer Map: http://tinyurl.com/saunsw-austicruise  RSVP: If you are planning to sit and have breakfast with us, please let us know, either by posting in the event, or by messaging us direct so we can confirm numbers with the venue. Itinerary: We will meet at Loftus Oval Carpark which has plenty of room and is low car friendly. This is a quick turn into the Royal National Park and some nice roads and scenery. After Stanwell Tops we will turn off and head onto the awesome Sea Cliff Bridge. Following this it is a short trip to Austi Beach Cafe. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • YO- have been searching and searching for an a31 chassis plug pinout, or someone who knows which wire is for tach.  ceffy was flooded past dash during a hurricane.  having an electrical gremlin appear. tach is wonky reading consistent with a short, and on occasion the right side of my speedo lighting will flicker just for a second then go back to normal.  if no pinout available does anyone know if the tach harness opens or branches anywhere behind the dash? im suspecting a possible root behind the radio as there are more shorts in that area on the accessory loop.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
