RaseR Posted November 13, 2006 Share Posted November 13, 2006 (edited) Hey Guys, Strange one for you all - ever since I've owned my S2 R33 (most of this year), I've noticed that whenever I take a slightly spirited drive through the windys, I can feel and see the steering wheel pulse left/right in my hands at irregular intervals...haven't had time to book it in to be fixed until now, so any ideas what I should be looking at? Variables: Car has standard airbag wheel, HICAS, upgraded castor bushes, runs on 18x8 350Z alloys (235/45), lowered springs (-30 to -40mm) Pls Let me know if you have any insights! Edited November 13, 2006 by RaseR Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/ Share on other sites More sharing options...
tacker Posted November 13, 2006 Share Posted November 13, 2006 does it pulse when you are braking? Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2667859 Share on other sites More sharing options...
RaseR Posted November 13, 2006 Author Share Posted November 13, 2006 Yep, when slowing from high speeds - but unfortunately that's only a really recent thing (discs have worn unevenly). Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2667914 Share on other sites More sharing options...
LiQuid IcE Posted November 13, 2006 Share Posted November 13, 2006 when I'm stopped and half turned the steering wheel ready to make a turn I can feel the steering wheel moving opposite to what ive turned in my hands maybe that feature's malfuntioned? Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2668322 Share on other sites More sharing options...
tacker Posted November 13, 2006 Share Posted November 13, 2006 Nope your disc maybe warped or you may have tempered a section of your disc making it a lot harder than the rest or worse cracked one of your discs. Once either of these take place then it just gets worse, and it sort of difficult for discs to wear unevenly. Try machining your discs if they are not cracked and they will soon let you know if you have a hard section on the disc when they skim it. Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2668357 Share on other sites More sharing options...
blind_elk Posted November 13, 2006 Share Posted November 13, 2006 Sorry, but I don't think it's got anything to do with warped brakes - why woud it do it while the car is stationary? I seem to recall a similar problem with my 32, and it had something to do with a poorly connected TPS, IIRC. Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2668959 Share on other sites More sharing options...
RaseR Posted November 13, 2006 Author Share Posted November 13, 2006 Thanks guys, but I'm not convinced it's the discs...like LiQuid IcE mentioned, it also does it while the car is stationary with the wheel half turned...(which I should've mentioned originally!) so that would rule out the brakes... blind_elk - that's an interesting one, I'm almost positive the TPS sensor is connected properly, I've used my consult diagnostic tool and can see that it reads (IIRC) around 0.3V on closed throttle and smoothly increases to 4.8V (once again IIRC) at full throttle...any other ideas? Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2669042 Share on other sites More sharing options...
blind_elk Posted November 13, 2006 Share Posted November 13, 2006 Then again, it might have had something to do with a bad connection on the back of the alternator (ie bad battery voltage). Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2669274 Share on other sites More sharing options...
mr_crust Posted November 14, 2006 Share Posted November 14, 2006 get ur rims balanced and get a wheel alignment..after you lowered it your alignment would have gone out of whack. or if you have driven over a pot hole or something like that , it will put ur alignment out Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2669403 Share on other sites More sharing options...
RaseR Posted November 14, 2006 Author Share Posted November 14, 2006 hey mr crust - good advice, I'm definitely going to get all that done, I suspect that an alignment wasn't done after the previous owner lowered it & also when the castor bushes were replaced. thanks blind_elk - I'll check out my alternator this weekend, just interested how this could affect the steering - I guess it must have something to do with it being speed sensitive? Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2670055 Share on other sites More sharing options...
lingeringsoul Posted November 14, 2006 Share Posted November 14, 2006 oh wow....i seem to have the same problem....not a big deal but annoying nonetheless and I still don't knw what the problem is Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2671818 Share on other sites More sharing options...
RaseR Posted November 14, 2006 Author Share Posted November 14, 2006 (edited) Hey lingeringsoul...nah, no big deal - hence the reason I haven't bothered getting it fixed...but yes it's kinda annoying! I'm going to get the full wheel alignment, balance, new p/s fluid all done with my major service, so I'll let you know if any of those solve the problem...not holding my breathe just quietly. Edited November 14, 2006 by RaseR Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2671838 Share on other sites More sharing options...
lingeringsoul Posted November 16, 2006 Share Posted November 16, 2006 wheel allignment didn't solve my problem......it's probably the power steering unit problem I'm thinking Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2679279 Share on other sites More sharing options...
RaseR Posted December 2, 2006 Author Share Posted December 2, 2006 Ok guys, for anyone who's interested - I've found out what causes this problem - it's actually the power steering rack, there are a set of teflon collars that interface the column to the rack, as these wear out and deteriorate it can lead to the pulsing that I'm experiencing. Apparently the only solution is to have the rack reconditioned. Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2721488 Share on other sites More sharing options...
mr_crust Posted December 5, 2006 Share Posted December 5, 2006 not good, any idea what its worth to do...or is it worth it at all Link to comment https://www.sau.com.au/forums/topic/143149-r33-s2-steering-wheel-pulses/#findComment-2729306 Share on other sites More sharing options...
