  • Replies 65
Posted Images
ok to get this moving more info
on the car is a cat back exaust 3" in think cat back 5inch cannon
4oohp heavy duty cluch used
car is white
i have a radiator support for a nissan cefiro
1 green cefiro front bar
full interior perfect condition
left pasenger gaurd in green
bonet in green
full rear cradle
doors drivers side only
passengerside quarter glass
boot
looms
afm
coil packs
feul tank
can chop wotever u need off it being roof rear quarter panels not really fussed
2 or 3 standard headlights
driverside indicator
front and back seats
dash
dash cluster auto with 89,000km on it
steering wheel
engine crossmember
all switches and looms
lots more stuff cant think off now just ask
driver side guard is gone
carpet is gone
manual console is gone
pasengerside vent suround is gone
dash cluster suround with vents are gone
Edited by drftnfrysi
after the stereo surround, passenger dash large vent surround, centre air con vent assembley for to more of the passenger side of the middle...
also the 2 lil square things close to front windscreen on the dash
look im i get on this sit 1ce a week so
stop being an impatiient bunch of f**ks
my number is 0412938223
call me all ur questions
tail shft ill get back to u on a price
handbrake cover not worth the effort
of shipping it to adilade for how much it's worth
rear bars fine bit of exaust fumes but it's whit $140
i need the window regs for the front pasenger door
and rear driverside sorry
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
