Motor cranks but theres no spark, we tested the actuator it seems to be alright. Im gonna test the coilpacks right now.
the thing is when we pull the spark plugs out and ground on it on the block, crank the engine and the spark plug doesnt spark.
I checked the igniter, it seems to be alright.
also when we undo the plug it doesnt smell like fuel as been in there.
Could it be something that is cutting the fuel and ignition?
Is there something else im missing? Someone have a diagram of the connectors?
https://www.sau.com.au/forums/topic/143202-fresh-rebuild-no-spark-no-fuel/
got the plug for the igniter plugged into the loom at the back of the head properly, same with the injector loom and injector plugs...have you checked the line for fuel coming out while cranking, if not perhaps pump, maybe fuse gone?
Check fuses (under dash) and relays (in engine bay). Check that the 2 relays behind theECU are switching when IGN -> "ON".
You should be able to hear the fuel pump priming at the initial IGN -> "ON".
