Hey guys, a whole heap of gauges were stolen from Justin Marshall's garage the other day (I'm sure a few people here know him). Can anyone let me or him know if they have any info. There was a lot of money worth in there.
Cheers
Scott
https://www.sau.com.au/forums/topic/143208-theft/
what sorts= of gauges? brands etc? so we can recognise if we see em for sale or something.
They were all Autometer silver pro series. 1 X oil press, oil temp, water temp, a gizmo shift light, JVC cd player and a laptop.
Also a Kawasaki KLX250R went missing from there not long ago too, possibly seen in Duffy somewhere.
Cheers
Edited by datto260Z
https://www.sau.com.au/forums/topic/143208-theft/#findComment-2688496
    • Yeah do that, it’s only 120kAUD!!! You should have that sitting in the ashtray
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
