  • 1 month later...
  • Replies 201
So in summary gotta fix the NEED list first, then comes the POWER list.
To Do list:
Radiator (leaking) Done, recoed unit installed
lower Radiator hose (leaking) Done, new upper & lower
2 leaking injectors (leaking) Done, replaced with 6x New items at $60each
o-ring around the overdrive solenoid on auto trans (leaking) Done
new filter screen and gasket on auto trans (leaking) Done
new trans cooler hoses (leaking) Done, plus new trans cooler from 34GT-T
new exhaust, partly for performance, partly cos it sounds like a farking steam train, and partly cos im loosing brain cells from the fumes (Leaking) Done, orignal system re-fitted and repaired, for $35...
new tyres & wheel alignment (bald) Done, somrather nice beauties fron Italy
front disks machined and new pads Done
new rear disks and pads
new wiper inserts (smudging the windscreen) Done
new LHS park light globe Doh! keep forgetting)
remove snapped bolt in head for rocker cover Really farked this one up, snapped a drill bit in it, then snapped an 'easy out' in it...)
new rocker cover gasket Done, $28
re-gap rocker arms (tap tap tapperoo!) Done, holy shit it makes a HUGE difference, there was double the amount of clearance needed. All sorted now, very very fiddly job, finished at 3am monday
new air con switch (fell to bits) Done
new rear window switch (fell to bits too) Done, reinforced with stainless steel nuts and bolts, will never brak again. ever.
fix divers door rubber seal (leaking) Done. 3M duble sided tape for the win!
clean out chrome roof trims (full of leaves and shit) To do in the morning, autosol to the rescue
new diff mounts, super pro or similar (current items go CLUNK every time you select or deselect drive, or accelerate/decelerate) )Still to do, dont have the part number
In preparation for the Nationals, I thought to strike a few tasks off the list....
still N/A at the momnt, didnt have time to boost it due to the good metal fab guys here in Canberra all booked out for the next 3 weeks. So I have the "TURBO' cam cover on, will have to coverup the 'turbo' word for the minute.
Pics to follow...
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
