  • 1 month later...
  • Replies 201
So in summary gotta fix the NEED list first, then comes the POWER list.
To Do list:
Radiator (leaking) Done, recoed unit installed
lower Radiator hose (leaking) Done, new upper & lower
2 leaking injectors (leaking) Done, replaced with 6x New items at $60each
o-ring around the overdrive solenoid on auto trans (leaking) Done
new filter screen and gasket on auto trans (leaking) Done
new trans cooler hoses (leaking) Done, plus new trans cooler from 34GT-T
new exhaust, partly for performance, partly cos it sounds like a farking steam train, and partly cos im loosing brain cells from the fumes (Leaking) Done, orignal system re-fitted and repaired, for $35...
new tyres & wheel alignment (bald) Done, somrather nice beauties fron Italy
front disks machined and new pads Done
new rear disks and pads
new wiper inserts (smudging the windscreen) Done
new LHS park light globe Doh! keep forgetting)
remove snapped bolt in head for rocker cover Really farked this one up, snapped a drill bit in it, then snapped an 'easy out' in it...)
new rocker cover gasket Done, $28
re-gap rocker arms (tap tap tapperoo!) Done, holy shit it makes a HUGE difference, there was double the amount of clearance needed. All sorted now, very very fiddly job, finished at 3am monday
new air con switch (fell to bits) Done
new rear window switch (fell to bits too) Done, reinforced with stainless steel nuts and bolts, will never brak again. ever.
fix divers door rubber seal (leaking) Done. 3M duble sided tape for the win!
clean out chrome roof trims (full of leaves and shit) To do in the morning, autosol to the rescue
new diff mounts, super pro or similar (current items go CLUNK every time you select or deselect drive, or accelerate/decelerate) )Still to do, dont have the part number
In preparation for the Nationals, I thought to strike a few tasks off the list....
still N/A at the momnt, didnt have time to boost it due to the good metal fab guys here in Canberra all booked out for the next 3 weeks. So I have the "TURBO' cam cover on, will have to coverup the 'turbo' word for the minute.
Pics to follow...
