These wheels came with my aristo and to get it through compliance I had to put nearly $1200 worth of 18" tyres on them
They are 18x8.5 and 18x9.5 with an offset of around +38 - +40 (dont know exactly)
Stud pattern is 5x114.3
The tyres are 245/40s and 265/40s respectively...
these wheels are worth around $4000 brand new...
im asking $1700
Pics are below:
The wheels are in awesome condition overall...apart from the small amounts of rash on the passenger side front and rear
price is not negotiable...
These are perfect for:
Celsior
Supra MK3 and MK4
Soarer Z20 and Z30
Aristo
Most 5 stud toyotas in fact
https://www.sau.com.au/forums/topic/143246-18x85-and-18x95-bbs-lm-iis/
    • By went out the old cluster completely died first it was the odo lcd then the gauges stopped working, Nissan said the board/chip went bad. I then ordered a used one off of amazon. I can transplant the speedo gauge itself I still have the old bad cluster. in fact I am trying to visually inspect to see any differences between the two. The back of the speedos themselves have a different number on the top one has a 5 the other has a 6 i believe printed at the top and the original motor looked a bit larger. On the board itself behind the speedo I saw a few differences looks like towards the bottom the my original board didn't have a resistor at R3. The SMD chip in the top right has some different numbers on it (maybe I can swap these) and the resistor at r16 might be different colors. So the new cluster came from a non turbo but it did have TCS the ebay seller said. hopefully these images will show:  New cluster broken cluster   I will try to transplant just the speedo first.
    • I'll match that and include 3 out of 4 of the speakers in a set of Alpine front splits.
    • *all RB25 s1 if I hadn't said yet, sorry guys haha
    • Yes, the speed sensors are quite different between NA and turbo. Completely different waveform. I'm surprised it's picking up any pulses at all if it is the wrong one. As to the original problem... "the instrument cluster went out". What does that mean? What died and how? Is there any hope that you could transplant teh speedo head from that into the new one?
