My rb20det shit a piston after getting tuned. Got another set of 20det pistons. mods are
t3/t3
40mm external
FMIC
injectors
exhasut everything to support big power.
Question is as i will have the bottom end in bits do rb25 crank and rods go straight in the rb20det with the 20det pistons?
I all so have spare 25 crank and rods here which i want to use. Has anyone done this before? Can anyone tell me if it actually works? From what i can gather it will make an rb22 or rb23?
Any help much appreciated.
Cheers,
Kingsley
https://www.sau.com.au/forums/topic/143254-rb20-to-rb22-or-rb23/
Where is the extra money for what? I got the pistons crank everything bar new bearings. Which it will most likely get anyway while it’s in bits.
Did you answer my question? NO therefore I didn't need you opinion. Why run an rb20 for no extra money when it could be rb23?
I don't see the point spending $1800 on forged pistons for an rb20 to make a midget 350rwhp when stockers do just fine. I would also not go rb25! For the cost of buying a 25 I am building a 500hp rb30det.
How ever that’s not what I wanted to know. I wanted to know if any one could actually tell me if it works! Tomorrow is another day and since no one has told me I’ll be ripping them to bits and find out for myself!
Hey guys, wierdly enough i read an article in fast fours not all that long ago, it was the september 2006 issue titled "Sinister Power For your RB". Straight up your ally dxcorolla. It goes into a little detail about what combinations ie crank, rods, and pistons to make RB21, RB22, RB23, RB24and even a RB25 but no real talk of machining issues. If you can't get a copy just give me a PM and I'll try to scan the pages and e-mail them to you. Good Luck i'll be following your journey closely as i'm a little worried about my bottom end too :pirate:
I would only do it if it made rb22 or higher but it needs bigger pistons to do so there fore I won't be doing it.
The rb20 bottom ends are fine, infact all rb bottom ends are good. get a good tune!!! It's all in the tune how long an engine will last.
Would be a good read if you could scan them pages 4 me. Probaly can't get the september issue i woudln't think.
cheers
well im building a leftovers then all the parts back in about 3 weeks at the machine shop now ,at long last
Roy here are some picks of RB26 rods and Rb20det rods from the measurement I have they appear to be same length to the bearting cap whereas from there they differ because the rb25 and 26 have bigger, big end bearings
post-7066-1163500426.jpgpost-7066-1163500443.jpgpost-7066-1163500464.jpgpost-7066-1163500480.jpgpost-7066-1163500501.jpg
Cheers Peter
I'll scan those pages for you dxcorolla when i get home, legend01 is right the article mentiond using 4AGZE forged pistons that are 81.6mm i think, with a little machining to fit( but no serious detail:( ) I think a RB30 conversion would be the go for the costs associated.
also the machining of semi circles in the block so the rods clear when the crank is on compression and exhaust strokes, 5mm deep from memory, with the 4agze pistons u have to machine the piston crown, which is a bit sketchy, they protude the block a little
pistons are the main let down cuz tomei 82mm are about $2000+ same goes with custom pistons that just leaves the 4agze
as legend01 said using the rb20det pistons only brings it to 2056cc by using the mathematical equation
hope this helps
cheers brad
And then you need to spend double that on the head to get it to actually flow something moderately decent... and then its more expensive than the RB25 ;)
Anyhow, the search button obviously wasnt consulted :P
http://www.skylinesaustralia.com/forums/in...*++RB23*++RB24*
http://www.skylinesaustralia.com/forums/in....2*++2.3*++2.4*
http://www.skylinesaustralia.com/forums/in...6&hl=stroke
http://www.skylinesaustralia.com/forums/in...3&hl=stroke
http://www.skylinesaustralia.com/forums/in...0&hl=stroke
http://www.skylinesaustralia.com/forums/in...c=90293&hl=
http://www.skylinesaustralia.com/forums/in...c=86271&hl=
And thats only half the threads as there are tooooooooo many to past.
So please use the search feature, it returns more useful information than this thread will probably get in it :)
Cheers - Ash
