I use mobil 1. I do alot of kms and change the oil at 10,000kms or earlier depending on the oil's condition and the type of driving I've been doing.
You can use a partially synthetic oil. I like the pentrite stuff for that. They have exellent high temp range oil 5w-70 and it's only $28. I use the 15w-70 in the volvo V8 and it's better than the mobil 1. I'm switching to the 5w-70 stuff for the skyline next.
I look at the cold start performance, the pressure stabillity under heat load and how much quicker the car is (if at all).
The pentrite stuff is as good as mobil 1 getting around the motor (mobil 1 is very good) at start up. Shuts the lifter noise up straight away. The pentrite stuff holds idle/stall oil pressure nicely, where as the mobil 1 required a higher rpm for idle to be set to ensure the pressure did not drop into the idiot light zone when the engine had a good thrash.
Basically the oil is great value for money. Oil is after all a disposable consumable for the engine and getting the most expensive oil does not do anything but burn a nice hole in the wallet.
Think about changing the gearbox and diff oil at 5-15,000kms based on the driving style you employ. Go to the drags once and the diff oil at least requires a change (you may notice the silvery metal particals that come out). I am constantly amazed by people who buy mega buck oils and then don't change the diff and trans fluid regularly. It's like driving around with sand in the gearbox.
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
    • Barrels don't need to be shiny clean. But they are certainly nicer when they are not polluted with years of brake dust, and worse the rotting corpses of the last 17 balance weight sticky pads scattered all around.
    • Yeah, type a special character like ^ or | to initiate the equivalent of the "at"ing for thread links. Although, it might not get any easier to manage. Imagine 30 or 40 threads that kinda match what you want, and the one you want is lost after a long list of useless ones. The magic keyword version I proposed would be a manual effort to set up each case. More of a directed effort from the greybeards to facilitate exposure of useful content. I'm not against the auto complete stuff being considered - maybe por que no los dos? (And where I said "triggered automatically" in my OP, I meant "triggered accidentally". Of course I want it to be automatic!!)
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
