Hi all
Does anyone know:
1) what size bulbs are behind main dash for speedo, fuel, water temp and tacho? and how many?
2) what size bulbs are behind the centre meter cluster? and how many?
3) what size bulbs are behind the aircon unit? and how many?
4) also are they bulbs you can simply replace by popping out the bulb and putting in a new one? note: I mean popping it out of the holder and putting purely a bulb back into the old holder.
Someone has said that they are T6.5 bulbs, but the actual T5 glass bulb part can fit into a T6.5 bulb holder.
Thanks
https://www.sau.com.au/forums/topic/143272-er34-gtt-lights-behind-dash/
im pretty sure the main cluster globes and the triple gauge cluster are t-5, but i modified mine to t-10
attached are picks of the globes from the climate control unit. i dont know the size but they are tiny. i modified them also to fit small LEDs in there.
it was a while ago i did this, but im pretty sure ther are six globes in total on the climate control unit. in the pic attached you have to also unscrew the section i have put a line around(it is tricky because of the hot/cold dial and the surrounding plastic) and the other thre globes are inside that section.
thanks
Justin
walkoau: any idea how many T5/T6.5 bulbs needed in the main dash? and the centre cluster?
Is it 4 for the main dash and 3 in the centre gauges?
Thanks
yep 4 in main cluster and 3 in triple gauge cluster, but i modified mine so i got 6 in my cluster.
  • 4 weeks later...
