Can someone settle this?
Say for example an HKS GT2530 turbo. HKS themselves rate this as a 300hp turbo, yet these turbos (singly on a RB25) can make at least 225kw(300hp) AT THE WHEELS, which means the engine is making closer to the 400hp mark.
Also i read somewhere on the forums someone SWEARING that a std RB25 turbo will not, and cannot make more than 300hp. Well this obviously cant be true, as heaps of people with std turbos -including myself-are putting out just over 200kw at the wheels at 12-14psi with tuning, which is somewhere around 350-380hp at the engine.
Cheers, NACHO.
https://www.sau.com.au/forums/topic/14329-turbo-ratings-wtf/
Hi Nacho Vidal, it's all in the numbers..........
200 rwkw is 250 kw (at the engine)
250 kw is 340 bhp
That's on our dynos (engine and chassis) it might be different on someone elses.
HKS rating for their turbos is always at least 10% conservative, they sell lots of stuff in the US and they don't want to get sued.
I have seen a R33 GTST RB25DET with the standard turbo make 220 rwkw (that's 370 bhp) at 1.4 bar (lots of other mods). So I know an R33 GTST RB25DET standard turbo can make more than 300 bhp. By the way it lasted 3 days until the ceramic turbine parted company with the shaft. The 200 rwkw we talk about is the "safe" limit of the turbo, not the "it won't last" limit.
Hope that helps.
https://www.sau.com.au/forums/topic/14329-turbo-ratings-wtf/#findComment-289568
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
