I would like to have some feedback on the d jetro version of the pfc.
I am going to be building a very high hp r32 gtr over the next year and I have no intention of using maf sensors.
I recently came across a 1034 rwhp r33 gtr that used a d jetro ecu.
I liked my previous l jetro pfc so i thought i would like to use a pfc again but this time with d jetro and datalogit
Would i be better of with a ecu such as microtech, tec 3 or anything else?
Edited by icydude
https://www.sau.com.au/forums/topic/143350-pfc-d-jetro-opinions/
If you have proper size AFM for your terget power. L-jetro is nothing to lose I beleive. If you do not have it, you have to use D-jetro is much better. Max power is almost same both of them if suction of a air is same condition. Any ECU are same. But the measurement of the air suction is most important thing for the power and response of the engine. AFM is on time measure but D is after suction a air.
head a read of the PFC FAQ in my signature, it covers the djetro vs ljetro pfc's. worth a read
Sure have :P
I am a frequent visitor to your site for the last year i would have to say.
I was really hoping for opinions from those who have tuned them or drive with them.
I wont have space for any mafs.
The turbo's life is shorter on a D Jetro ...this is why I did not take this path.
For the figures you are looking at though it is the best option...for value for money that is.
But if you are well cashed up, thats another thing :P
What are you planning to use it for?Track or Drag
To my readings the turbos are not limited by the air flow meters and are spinning at higher revs
to begin with...this is why responce is quicker.thus turbo life is shorter.
Most of the WA guys swear by the better set up using the D Getro vertion of the power-fc.
Correct me if any one actually has heard different. :P
AFM dont' control turbo i believe.
Maybe turbo life shorter because you don't use the AFM anymore, don't use air filter either (like the crazy jap) so sometime flies got suck through! ;).
Correct me if any one actually has heard different. :)
wrong. :P
AFMs dont limit turbos at all.
Its jsut the WA tuner in question gets better results.
Same as a Vic tuner gets excellent results here using AFM's
Its just the ECU that the tuner is comfy using.
AFM's are not a limitation
I've heard that D-jetro pfc is a very crude ECU. lumopy idle, bad fuel consumption. It is used only in high hp applications as afm cannot read tha high air flow even the Q45 ones....It is not recomended for hp which is manageable bt afm.. anywas out of curiosity does D-jetro veersion comes in witht he MAP sensor or have to buy seperately.
I think D-jetro is the cheapest out of all the pfcs
you buy the djetro pfc and commander for 71000 yen. Then you need to buy the djetro sensor kit and harness which is another 33000 yen.
You've "heard" a lot of bunkas
ahh you are basing this comment on? which part of my response is bull ~~
this is my sourse:
The D-Jetro Power FC units carry the same functions as the regular Power FC units but do not require the use of the factory standard air flow meter and use a mass air pressure sensor. Apart from the unit itself, use of the D-Jetro units requires additional parts that vary depending on the model." - www.greenline.jp The airflow meter (at least in the skyline range) does not pose a big restriction in terms of horsepower and one would doubt the use of the D-Jetro. If you really need massive airflow you can always change to 2 x Q45 Airflow meters and use those with the PowerFC. The skyline series are optimized for closed loop operation with an airflow meter and oxygen sensor for feedback and measuring. Cars the run on a MAP sensor system can suffer drawbacks such as bad idling, poor fuel economy, problems with cold starts etc
from Paul's manual
the costing come from:
http://www.nengun.com/catalogue/brand/1
remeber that you have to add MAP sensor cost to D-jetro
and the "heard term" is literally from a tuner in W.A, you can pm me for his number if you are not satisfied
so...now which bit again?
Sky34, I agree with Gav, what you've been told is not true. I know at least 4 De Jetro tuned GTR's in WA which have no problems with idle or fuel consumption. There is a trick to getting the idle right with multiple throttle bodies. I'm sure the tuner you spoke to just doesn't like De Jetro's which is fair enough, but they are a very good product for high hp cars.
Cheers
Paul
hi guys
yeah im sorry the stuff i had in the pfc faq under the djetro area is a bit outdated and the opinion was a bit off with no real evidence. there are a few caveats you need to know about when using djetro pfc, and presumably others
- careful placement of map sensors
- tuning takes a lot more time, much more than afm
- have to buy extra djetro parts and connect it up
Correct me if any one actually has heard different. :no:
In simple terms, they offer better performance then if they respond better!!!!
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
