there is no logical reason a djetro vs ljetro would make more power or response. if anything the afm should offer better response and load points as its measure air volume and not guessing via pressure
My English is not good enough for you. But there is reason L-jetro is much better than D-jetro. D-jetro is pressure measure that means for exsample same pressure tires, one is big truck tire and another is small car tire. Both of them are same pressure but air capacity of the tire is diffrent quantity. There are many logic which one is better and many people, even engineers told about it much. Some people said "Show me show me how do you prive it?" But all logic is so far and coming new always.
dont forget your limited to 2bar boost and under with the d-jetro with the map sensors they use, if u plan on serious power remember this before u spend your cash :rofl:
i dont know of anyone who has modified a 3 bar map sensor to work with the djetro as yet, i do know one shop who has been trying to do it for a long time and im pretty sure they havent worked it out.
go a full standalone ecu like motec, autronics, etc and u will be very happy with the results and they have internal datalogging, and antilag and all the stuff u could possibly ever want.
thats just my 2c
thats just my 2c
Just my 2c :P
Charles' law (sometimes called the Law of Charles and Gay-Lussac) is one of the gas laws. It states that at constant pressure, the volume of a given mass of a gas increases or decreases by the same factor as its temperature (in kelvins) increases or decreases.
That is, you're not 'guessing' an air volume if you know it's pressure (measured by MAP sensor) and its temperature.
Regards,
Saliya
I dont see any reason why a gm 5 bar map sensor or 4 bar could not be adapted to work.
You can program 5 differnt including the stock on it comes with.
Just like as if you were using the l jetro with diff afms.
The sensor is just sending an electronic signal which you can interpret to mean anything really.
But as said before an extra grand wont break the bank but when it comes down to it all i need to ignition and fuel. I just dont want to go spend 6 grand on a full motec setup when a pfc "should" work.
just an update, moving to a higher rated map sensor is easy
the rxr7 guys do it quiet often when they crank the boost up
you need datalogit to edit the map scale and offset
two text boxes and its done
Regards,
Saliya
ok but if i have car tyre with air at 30psi and a truck tyre at 30psi
both have same air temp, clearly they both have different are volumes
i cant see anywhere in the datalogit of powerfc to support that it uses the air temp for "load" calculate, the load axis guesstimation is based on map sensor signal and thats about it. it doesnt use the air temp for placement, but more for correction when its really hot (back off timing). i would the map sensor to be temperature aware, but unsure if it would use this value in showing "air pressure" to the ecu
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
