if you want your stock turbo to last you then 10 psi is all good, more than that starts to get unsafe, although i have heard of peoples stock turbo lasting ages on 14 psi :)
but yeah, 10 psi is safe, i wouldnt go more than that :laugh:
I plan running mine dual stage, 7psi for low everyday use and 12 psi for drags and when I want performance. What do u all reckon? Stock everything execpt turbo back exhaust and soon to have fmic
12 psi is a good one to have with dual stage
i use it and dont see the ecu going rich and retarded like it did on 14psi !!!
so 12's orite, if you really want perfection checks the afrs, tune, safc, etc but really just for drags yeah man 12's just fine if u running 7 psi everyday
p.s any more tho asking for trouble without a bigger front mount and basic mods
Edited by Zas)-(
What about with a stock exhaust BUT with a R34 SMIC, what boost?
7psi....as I have been kindly directed by members of this forum :verymad:
Its no good for your turbo to be trying to blow through a tiny pipe that has a few 90 degree bends.
What happens when you blow through a small straw a lot harder than normal??........ Your face goes red and heats up.......so does your turbo :thumbsup:
7psi....as I have been kindly directed by members of this forum :D
What happens when you blow through a small straw a lot harder than normal??........ Your face goes red and heats up.......so does your turbo :D
but when i put the R34 SMIC it went to 8psi automatically, so surely 1psi more cant hurt it can it?...Im no expert tho, so any thoughts would be appreciated.
Are you sure your boost went up when you put the smic on? or was it the BC that you put on.
I did this same mod to my car, and boost didn't go up.
I'm no expert either, but it doesn't take an expert to tell you that your performance gains will be minimal until you do your exhaust.
Sure you can bump the boost up a bit, you'll definitely feel it pick up better down low, but overall performance won't increase by much, along with you putting unnecessary strain on the turbo.
yea was before i got boost control & still had std dual stage bleed 5/7psi...as soon as i out on SMIC i noticed it hitting 5psi alot earlier & also went to just under 8psi instead of 7psi
yea down low is awesome now & i agree without an exhaust not much gain in power is to be had especially in higher revs but just want to know whats a safe boost til i get an exhaust and power fc later on
As I said when I had a full exhaust and pod filter 10psi was fine had no dramas with it whatsoever. I wouldnt go any higher than that on the stock cooler though as there not very good at scrubbing the heat especially as we are getting into the hotter period of the year. I would leave your boost as is till you get an exhaust.
Cheers
Chris
Cheers
Chris
1001 threads on this....serach..
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
