im running a 18 pound actuator and a brand new PFC boost control kit.
attached is a dyno print out showing the wave.
i have installed a 2mm restrictor in the feed line to the solenoid and the results are on the printout.
before i installed the restrictor it was even worse.
the boost settings are on 1.6 kgm cm
and the duty cycle is on 83 %
its a built rb25det with the new gt3540-iw
if i go any higher with the boost the wave gets bigger, and longer.
does any one have any other solution?
cheers Darren
Edited by dangerman4
https://www.sau.com.au/forums/topic/143365-r33-pfc-boost-controller-issues/
how are the results varied when you adjust the duty cycle?
how is the solenoid connected? (draw a diagram)
where is the map sensor connected to (diagram would help)
the map sensor i joined with a T fitting into the line to the EBC from the plenum
and the wires plug directly into the pfc
the solenoid is wired up as you suggested in your pfc thread.
and checked with a multimeter.
if i go any higher with the duty cycle it becomes even more unstable.
What Paul suggested plus.......
Since you aren't using the EBC, reduce the amount of vaccum tubing, it's just buffering the signal to the PFC map sensor.
:O cheers :)
:O cheers :)
Sorry Gary you have lost me.
i have a bad headache.
what ebc are you talking about?
where do you recomend running the lines from for the ebc?
should i get a fitting put into the outlet of the comp cover?
or what?
also should i plug the map sensor into the bov instead?
cheers
also to note the FC has a boost cut protect mode which may be activating, if the boost spikes 0.25kgcm2 over the value you dial in under SETTING, BOOST it will perform boost cut and back itself off. you may be hitting this, i would expect the engine check light to come on however
Looking at the boost curve it appears that the initially required duty cycle (at 3500 rpm) is not set correctly to meet your boost target of 1.6kg/cm).
1) At 3500 rpm your turbo is finally making enough pressure to overcome the actuator spring pressure. Prior to this your 2mm reducer and bleed off valve have no effect.
2) The sudden reduction in boost pressure after 3500 rpm is due to the solenoid bleeding off too much pressure. The duty cycle is too low at this point (even at 85% open) and the waste gate has opened too much due to too much pressure on the actuator. This suggests the reducer is incorrectly sized and you need to reduce the duty cycle (overall) in order to gain some control at the onset of boost - 3500rpm. My guess is that a bigger reducer would give you better control of boost at this point. The 2mm reducer cannot relieve enough pressure fast enough at this point and the waste gate is opening too much.
3) The boost response from say 4500 rpm to 6000rpm is fairly normal.
4) To retain a flatter boost curve after 6000rpm a multi channel boost controller might be needed to pull down the duty and open the waste gate as this turbo really starts to come on steam. A simple proportional controller as per the PFC may not be able to act fast enough in this sort of situation.
Holy f**k Sticks Batman!
Have a look at the boost of the Gizzmo!!
It's almost vertical!
What was that like to drive?
as its my wifes car she loves it, and my 2.5yr old daughter squeals out "More Boost Mum"
Being a auto it gets very interesting very quickly.
Steve might be able to shed some light as he made 320 something rwkw through a HKS3037 + all the nice bits to get there with 20 something psi with perfect boost control
You 'may' want to give Shaun a buzz as he tuned Steve's many years ago and knows them like the back of his hand.
Just like the AVCR they can be a hassle to setup.
Can anyone post the top attachment as I can't seem to view it. I also have the PFC boost kit and my boost curve is also like a wave and its affecting the whole power graph, im not sure if the self learning thing has changed it since the tune ill have to get it on a dyno again to check it out.
are you referring to 255 on the boost screen? its not used but apparently its part of the logic control. the manual doesnt say shit about it, datalogit cant touch it and the hand controller cant touch it
as stated in the original post the boost is set at 1.6kgcm2
yet boost is only making 21 psi! how would boost cut be activating?
does anyone have english instructions for the pfc boost kit?
i have posted the dyno graph in the original post
cheers
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
