front end of evo reminds you of a 34!? WTF...its great to see that the lancer is a completely different shape and does not look one bit like the older model, the subaru just looks like another wrx with a few cosmetic changes
EDIT: a side shot would be great
Edited by thorpe84
The EVO front looks like a Veilside kit gone wrong.... more wrong than they usually are... that's pretty wrong.
STI front looks good but the shape of the body makes it look like a CRX, very similar to a shopping trolley. I hope it's just the angle of the pic that makes it look like that.
After over 10 years of STi vs Evo, Subaru finally make the STi look better than the Evo...
... but that's if those concept pictures depict the production versions
wethjer they made it look better or mitsu made it look worse is debateable :S i rekon EVO X is ugly
The subi and mitsu look the same hey... same general lines...
And why put a 6cyl in them to whoever said that? Look at it this way, if you had a size 6 foot, you wouldnt buy size 4 shoes. THEY DONT BLOODY FIT!!!
so you reckon the 6pot boxer doesnt fit a rex? :no:
No I know they do. As I have seen it, with all the gear etc. But in terms of what its going to do to the rest of the cars handeling and dynamics, and factory fitting it...
And as old mate was revering to both, I cant see mitsu fitting a 6cyl that is BETTER than what they have now in the evo.
That and they are marketed as 4 bangers. Thats the market they are in. You put a 6 in either and it puts it in a different market.
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
