antone have u offered anyone over 9k? this guy is trying to sell his car for $13500 and u r just insulting him and others as well including myself and everyone else you have tried to offer well below what myself and they have been asking for their cars. How about you get the money this person is after and then perhaps make a genuine offer not like the offers you've been making on EVERY R32 for sale - from what I've seen the cars have been selling for 12k + and uve been offering around 10k which you say you don't have. You've mentioned you have 7k... get some $$ and then make some genuine offers instead of wasting people's time.
Oh and thats a nice looking R32 buddy...good luck with your sale... I think we are all having issues with selling our 32s now and people like this guy (ANTONE) don't help... good luck
Edited by [SKYXTC]
https://www.sau.com.au/forums/topic/143393-sold/#findComment-2681956
' date='17 Nov 2006, 09:22 PM' post='2681956']
That was so uncalled for.
I used the report post button for the first time :( lets see how that works
https://www.sau.com.au/forums/topic/143393-sold/#findComment-2687940
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
