fishy Posted November 15, 2006 Share Posted November 15, 2006 Me and my friend decided to change our guages (both have a r34 gt-t). so yeah what do you guys think... which 3 guages would you put on your triple cluster and why? Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/ Share on other sites More sharing options...
paulr33 Posted November 15, 2006 Share Posted November 15, 2006 the stock cluster already has the most important ones Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2674963 Share on other sites More sharing options...
RB20_ZED Posted November 15, 2006 Share Posted November 15, 2006 boost oil pressure oil temp Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675032 Share on other sites More sharing options...
Mr. Keets Posted November 15, 2006 Share Posted November 15, 2006 Fuel pressure Oil pressure Boost Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675037 Share on other sites More sharing options...
kyle785 Posted November 15, 2006 Share Posted November 15, 2006 i believe he askked for reasons too not jsut what gauges Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675046 Share on other sites More sharing options...
paulr33 Posted November 15, 2006 Share Posted November 15, 2006 if you are tuning exhaust temp wideband af ratio if you arent stock boost is fine stock oil is fine maybe oil temperature Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675056 Share on other sites More sharing options...
R.R Posted November 15, 2006 Share Posted November 15, 2006 the stock cluster already has the most important ones hahaah BATT VOLTAGE>>> RIGHTO then Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675063 Share on other sites More sharing options...
Cubes Posted November 15, 2006 Share Posted November 15, 2006 Fuel pressureOil pressure Boost Thats not a bad combination. I'd probably trade boost for oil temperature. Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675090 Share on other sites More sharing options...
paulr33 Posted November 15, 2006 Share Posted November 15, 2006 given that he has said nothing as to what the car is used for then the stock guages are fine Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675097 Share on other sites More sharing options...
Cubes Posted November 15, 2006 Share Posted November 15, 2006 Maybe he's after a little wank(er) factor... A fully sik AFR guage BOOST guage to see how much BOOOST its running/ Speed to 400km/h Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675106 Share on other sites More sharing options...
PHATR32 Posted November 15, 2006 Share Posted November 15, 2006 vacuum gauge (dont need boost) clock (tasmania time) clock (london time) as mensioned above, the stock ones allready show the most important stuff. just upgrade them to nicer looking units Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675114 Share on other sites More sharing options...
paulr33 Posted November 15, 2006 Share Posted November 15, 2006 haha Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675122 Share on other sites More sharing options...
Andi Posted November 15, 2006 Share Posted November 15, 2006 (edited) Maybe you guys are forgetting the fact that he said its a GTT. I hardly find the stock volt guage useful. Since the stock dash already has oil pressure I'd keep the oil temp guage in the stock cluster and change the boost guage to a better one and the volt gauge to water temp. Edited November 15, 2006 by OnGsTa Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675583 Share on other sites More sharing options...
shonen Posted November 15, 2006 Share Posted November 15, 2006 Im in the process of changing the guages as well.. Already got the defi boost guage on the a-pillar and will get Oil pressure, Oil temp and exhuast temp when the time comes.. was thinking of getting water temp but thats on pfc handcontroller so decided against it. Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675588 Share on other sites More sharing options...
leb Posted November 15, 2006 Share Posted November 15, 2006 vacuum/boost gauge - it shows if there are any "boost" leaks a/f gauge - see whether your sensors are working properly and that your car is getting the optimal fuel to air ratio at various RPMS oil pressure - only if you're doing serious work and have changed the oil pump or anything oil system related oh oh dont forget. the MONSTER TACHO BRO! with a "hectic" shift light, you really need one of those because your car doesnt already come with a tacho standard or anything.... Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2675616 Share on other sites More sharing options...
R31Nismoid Posted November 15, 2006 Share Posted November 15, 2006 Oil temp Oil pressure Boost + Water Temp Thats my pick, yes it 4, but thats just how it is. But then the PFC tells me water so that kinda doest need a gauge Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2676041 Share on other sites More sharing options...
eMsta Posted November 15, 2006 Share Posted November 15, 2006 wouldnt it be better to change the guages or add more relevant ones if the car has been modified heaps and is used for track days and that kinda shit? The only use i see for these guages (if the car is not modified) is that they tend to raise the female curiosity (my friend regularly gets women looking at his wrx at night because of how the cabin is illuminated by the guages - but his car is modded heaps) Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2676073 Share on other sites More sharing options...
LBR33 Posted November 15, 2006 Share Posted November 15, 2006 Oil temp Water temp Oil pressure Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2676079 Share on other sites More sharing options...
Kaido_RR Posted November 15, 2006 Share Posted November 15, 2006 if you are tuningexhaust temp wideband af ratio if you arent stock boost is fine stock oil is fine maybe oil temperature stock oil is not fine its very common for the sender to f**k up in the r32/33 (not sure about r34); then you sometimes very values of almost zero and other times its fine Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2676116 Share on other sites More sharing options...
Cubes Posted November 15, 2006 Share Posted November 15, 2006 You can have the pfc also displaying boost if you fiddle a little. There's mention of it in pauls r33 faq I think. Link to comment https://www.sau.com.au/forums/topic/143416-which-is-the-3-most-recommended-guages-to-have-on-a-turbo-car/#findComment-2676248 Share on other sites More sharing options...
