Maybe you guys are forgetting the fact that he said its a GTT. I hardly find the stock volt guage useful. Since the stock dash already has oil pressure I'd keep the oil temp guage in the stock cluster and change the boost guage to a better one and the volt gauge to water temp.
Edited by OnGsTa
Im in the process of changing the guages as well..
Already got the defi boost guage on the a-pillar and will get Oil pressure, Oil temp and exhuast temp when the time comes..
was thinking of getting water temp but thats on pfc handcontroller so decided against it.
vacuum/boost gauge - it shows if there are any "boost" leaks
a/f gauge - see whether your sensors are working properly and that your car is getting the optimal fuel to air ratio at various RPMS
oil pressure - only if you're doing serious work and have changed the oil pump or anything oil system related
oh oh dont forget. the MONSTER TACHO BRO! with a "hectic" shift light, you really need one of those because your car doesnt already come with a tacho standard or anything....
wouldnt it be better to change the guages or add more relevant ones if the car has been modified heaps and is used for track days and that kinda shit?
The only use i see for these guages (if the car is not modified) is that they tend to raise the female curiosity (my friend regularly gets women looking at his wrx at night because of how the cabin is illuminated by the guages - but his car is modded heaps)
if you are tuning
exhaust temp
wideband af ratio
if you arent
stock boost is fine
stock oil is fine
maybe oil temperature
stock oil is not fine :thumbsup: its very common for the sender to f**k up in the r32/33 (not sure about r34); then you sometimes very values of almost zero and other times its fine :verymad:
    • Gosh these Rb pulleys/alternator or whatever is causing the problem is absolute rubbish lol. Haven't even done that many km on it.
    • Yeah man, will only progress further hopefully. The bonnet is coming off to get sprayed very soon
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
