  • Replies 131
I'd do Wollongong but it's too far for most.
My suggestion is Thursday 30th. Slide will be down. Will Col-GTSX still be here?
I will come.
There is a good pizza and pasta place near me in Sutherland, plenty of parking...
Im happy with the 30th :)
I would like to catch up with Slide and meet Col-GTSX :P
Awesome :no:
And I dont mind south for dinner :)
Yiannis in Wollongong - I know its a long shot, but who knows.
Great greek food - souvlaki for 2 is teh win!
Yeah sorry the gong is a bit far for us :no:
But you should come to the dinner on a Saturday night :)
pretty sure will be one in December :P
I will come.
shire :P
j/k easier for me anyway...better take down the dice then :no:
Edited by mr 32
sorry Bec, beat you to it!
but i still say ours are better than what we saw!
haha you haven't seen dave yet... he shaved the beard and left the mo! lol
oh and Jess, Col will be here on the 24th... I'll keep you updated on what's happening there... but we'll more than likely head down to The Ranch for a few quiet drinks and some dinner.
30th is good for me too, doesn't matter where abouts. We can car pool the North Shore folks.
Yep we can car pool for sure
thanks
I'll leave my boxing gloves..and you can leave your dice :verymad:
LOL
I need suggestions
*Sticks thumbs out to hitch a ride...
I need suggestions
please people
Indian
Chinese
Thai
Italian
Russian
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
