  • Replies 126
Small batches are still being made of the Power FC's with the next one being finished on the 25th but production has definately slowed and is messing with business for some reason :P
And with that price will surely raise quite a bit won't it?
Bought one from JPS Trading on eBay just a few minutes ago, $754 US shipped to Sweden.
Only four RB25DET R33 PFC:s left on eBay, better hurry :verymad:
lol, looks like when i decide to ditch my pfc (whenever that time comes) i'll be able to pull some coin for it.
kinda sucks tho as the pfc is possibly the best drop in replacement for our motors, aem is fickle and works half the time and the others are just horribly expensive or dont support maf.
My supplier still has a bundle... maybe apexi' is just messing with us to make a quick buck?
But i did hear a while ago that it was becoming hard to make a buck in the performance parts game over in japan - i find that a bit hard to believe but i'm not an apexi executive and i dont know what the overheads and supplier costs are.
this sounds about right. its one of the main reason apexi pull out of the d1 in japan and move over to the drift series in the US. they said there wasnt a big enough market for there products or something!
also my supplier still got many of them too :)
Straight from the horse mouth so to speak.
Hey Chris,
And i quote
As for the Power FC’s well the rumors are kind of a bit true but not completely, we can still get hold of most of them except for the R33 GTST, R34 GTT which are discontinued and there is no stock of. The S14 Series 1, S14 Series 1 D-Jetro, MR2 SW20 and the GC8/GF8 (A~C) are also discontinued but there is still a limited amount of stock available of these units. Everything else is fine, maybe not in stock but still under production. There will be stock of everything except the discontinued models listed above by the end of December for some and by the end of January for others.
What I have said in that they are discontinued isn’t to say that they will never be coming back into production but as they can not say when they plan to be they have classed all of them as discontinued.
Well hopes this helps a little.
Hey Chris,
And i quote
i vote for the guy that wrote that for prime minister!!
' date='16 Nov 2006, 05:25 PM' post='2678749']
why doesnt everyone just wait and see what apexi brings out next
im sure there will be a replacment for the pfc and im sure it will be better
They probably will...but no doubt it'll be more expensive and have a host of features that I do not want or need :)
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
    • Appreciate the insight! Talked to some local folks and they basically told me "it's not that deep." As long as the threading on the inside matches what's at the steering rack, everything else can be constructed-to-fit. There are full aftermarket kits I can use - probably better for my car overall since it's lowered.  Example: GKTech M14 Super Adjustable Inner Tie Rod Set - Nissan Skyline R32 R33 R33, 240SX, 300ZX, 350Z / Infiniti G35 M14I-TROD-2 gktM145-TROD gktM14I-TROD - Concept Z Performance (These can be packaged with their "high misalignment" tie rod ends).
