  • Replies 93
Now that the hks is not a option....Would a standard manifold thats been extrude honed produce the same power if not better then the 6boost ones? Im from WA and havent heard of any companies here that can extrude mine. Cbf sending it over east. Rather just order a 6boost one.
Spoke to the supplier of the HKs manifold. They actually do mount the turbo lower and on a slightly different angle then stock. In the case where im using a HKS GT2835 and turbinless kit...its pointless.
Longer oil and water lines need to b made
New dump pipe
Modify or Make a new intake pipe
Block off the external wastegate provision or Use an external gate and disconnect the internal gate. That sucks!
You do realise the 6boost manifolds are high mount...
Your going to have to make the same modifications as the turbo instead of being mounted lower will be mounted higher.
ahh the beauty of modified OEM :mad:
Sorry to say that it may be a while before i can show you on-car results, as i am not in the same country as my car, and have to organise other people to do stuff for me..
With turbine housings it can work very well mainly because it takes the ridges off the internal passage and reduces the depth of that boundary layer effect you get with fluid flow . Also any casting flash goes as well . The process is good for manifolds because it takes more from the constriction points ie round bends where its difficult/impossible to get at any other way .
Getting them ceramic coating does the same thing with regards to surface finish. Im interested to know if someone has had a manifold extrude honed then tried to ceramic coat them. Doesw the ceramic coating have any problem in the smoother surface?
I was considering ceramic coating it also! But then it really starts to add up cost wise.
The guy that did my manifold told of a stock SR manifold that whilst on the dyno would glow red, and once ex honed, it would not glow, due to the smoother passage of air and less friction/restriction. This would mean less heat radiated from the mani and lower underbonet temps, i could only imagine ceramic coating making the situation even cooler! Yet doesnt the process cost around as much as the honing process itself?
depending on how long it takes me to organise to get the manifold put back on, if some spare dollars come up i may yet do it, as id ultimately like to make the stock mani as good as it could possibly be before bolting it all back up!
Any comments on my after results? Whilst the runners dont flow as consistent as the HKS mani, the overall figures are higher than those posted for an HKS extrude honed mani. Does this mean that my stock item is now as good if not better than an HKS one, or even an ex honed HKS one??!@
HKS ex honed avg 201
Stock ex honed avg 202
I was going to get my HKS manifold ceramic coated after I had it honed but was advised against by both james and compition coatings as there would be a chance, how ever slight, that it might peal of the inside on the smooth surfaces but the outside no worries ,So still debating on wheather to get it done
Cheers Peter
6boost manifolds do come in low mount. Only thing is that they bolt the turbo not exactly in standard postion. Instead the turbo flange faces down rather then out 90 degree to the block. Once again no good with turbo kits. Any idea whats need/modifed to suit hks gt2835 kit?
  • 5 months later...
check out these two manifolds, HPI on the left and x-force on the right
Seems like the HPI has a better design then the xforce...It seems to be equal length and merge smoother and in the same direction at the turbo flange..Considering the stock turbo postion is very restrictive, HPI has done not a bad job??
i have tested back to back with std turbo and those styles of manifolds and found no decent increase, the HPI style on the other hand does offer a noticeable increase.
the only place i can seem to find them is directly from HPI in japan
http://web.mac.com/emihpi/iWeb/Site%2017/E...20Manifold.html
Does anyone know of any australian distributors? Are they durable or prone to crack? Do they bolt on without furthur modifications?
cheers
Edited by ovabooster
im no expert in exhaust manifold but man are the xforce crap! I only really noticed when i sat them both side by side...Just look at how the exhaust gases would flow when leaving the cylinder head...Almost at a 90 degree angle!! Not smooth at all...then look at runners 2 and 3....flow at 90 degress to the 1st runner!!! Big time turbulance...Lastly notice how all the runners merge onto the turbo flange...instead of entering directly into the turbine housing, its off to the side...Correct me if im wrong thou? Just my 2 cents :)
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
