  • Replies 93
Now that the hks is not a option....Would a standard manifold thats been extrude honed produce the same power if not better then the 6boost ones? Im from WA and havent heard of any companies here that can extrude mine. Cbf sending it over east. Rather just order a 6boost one.
Spoke to the supplier of the HKs manifold. They actually do mount the turbo lower and on a slightly different angle then stock. In the case where im using a HKS GT2835 and turbinless kit...its pointless.
Longer oil and water lines need to b made
New dump pipe
Modify or Make a new intake pipe
Block off the external wastegate provision or Use an external gate and disconnect the internal gate. That sucks!
You do realise the 6boost manifolds are high mount...
Your going to have to make the same modifications as the turbo instead of being mounted lower will be mounted higher.
ahh the beauty of modified OEM :mad:
Sorry to say that it may be a while before i can show you on-car results, as i am not in the same country as my car, and have to organise other people to do stuff for me..
With turbine housings it can work very well mainly because it takes the ridges off the internal passage and reduces the depth of that boundary layer effect you get with fluid flow . Also any casting flash goes as well . The process is good for manifolds because it takes more from the constriction points ie round bends where its difficult/impossible to get at any other way .
Getting them ceramic coating does the same thing with regards to surface finish. Im interested to know if someone has had a manifold extrude honed then tried to ceramic coat them. Doesw the ceramic coating have any problem in the smoother surface?
I was considering ceramic coating it also! But then it really starts to add up cost wise.
The guy that did my manifold told of a stock SR manifold that whilst on the dyno would glow red, and once ex honed, it would not glow, due to the smoother passage of air and less friction/restriction. This would mean less heat radiated from the mani and lower underbonet temps, i could only imagine ceramic coating making the situation even cooler! Yet doesnt the process cost around as much as the honing process itself?
depending on how long it takes me to organise to get the manifold put back on, if some spare dollars come up i may yet do it, as id ultimately like to make the stock mani as good as it could possibly be before bolting it all back up!
Any comments on my after results? Whilst the runners dont flow as consistent as the HKS mani, the overall figures are higher than those posted for an HKS extrude honed mani. Does this mean that my stock item is now as good if not better than an HKS one, or even an ex honed HKS one??!@
HKS ex honed avg 201
Stock ex honed avg 202
I was going to get my HKS manifold ceramic coated after I had it honed but was advised against by both james and compition coatings as there would be a chance, how ever slight, that it might peal of the inside on the smooth surfaces but the outside no worries ,So still debating on wheather to get it done
Cheers Peter
6boost manifolds do come in low mount. Only thing is that they bolt the turbo not exactly in standard postion. Instead the turbo flange faces down rather then out 90 degree to the block. Once again no good with turbo kits. Any idea whats need/modifed to suit hks gt2835 kit?
  • 5 months later...
check out these two manifolds, HPI on the left and x-force on the right
Seems like the HPI has a better design then the xforce...It seems to be equal length and merge smoother and in the same direction at the turbo flange..Considering the stock turbo postion is very restrictive, HPI has done not a bad job??
i have tested back to back with std turbo and those styles of manifolds and found no decent increase, the HPI style on the other hand does offer a noticeable increase.
the only place i can seem to find them is directly from HPI in japan
http://web.mac.com/emihpi/iWeb/Site%2017/E...20Manifold.html
Does anyone know of any australian distributors? Are they durable or prone to crack? Do they bolt on without furthur modifications?
cheers
Edited by ovabooster
im no expert in exhaust manifold but man are the xforce crap! I only really noticed when i sat them both side by side...Just look at how the exhaust gases would flow when leaving the cylinder head...Almost at a 90 degree angle!! Not smooth at all...then look at runners 2 and 3....flow at 90 degress to the 1st runner!!! Big time turbulance...Lastly notice how all the runners merge onto the turbo flange...instead of entering directly into the turbine housing, its off to the side...Correct me if im wrong thou? Just my 2 cents :)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
