THIS 1994 R32 GTR HAS BEEN FRESHLY REPAINTED FACTORY WHITE AND INCLUDES A JUN FRONT BAR, JUN FIBREGLASS BONNET FINISHED OFF WITH GOLD WORKS EQUIP 18x10 INCH WHEELS.
THE FRESHLY REBUILT RB26 MAKES 350KW+ AT THE WHEELS ON 20 PSI WITH NO LAG!!!!!!! THE ENGINE REBUILD INCLUDED A 700HP GARRETT SINGLE HIGH MOUNT TURBO, TIAL WASTEGATE, 87MM JE PISTONS, JE RINGS, REV RODS, HKS 264 DEGREE 8.7 MM LIFT CAMS, HKS ADJUSTABLE CAM GEARS, JUN BAFFLE SUMP, EXTENSIVE HEAD WORK INCLUDING CC’D CHAMBERS AND 5 ANGLE VALVE CUT, NEW VALVES AND BRONZE RETAINERS. COST FOR REBUILD WAS $20K PLUS AND ONLY DONE 3000 KMS SINCE.
THE FUEL AND IGNITION IS MANAGED BY AN APEXI POWER FC ECU WITH HAND CONTROLLER, Z32 AIR FLOW METERS, SPLITFIRE COILS AND A FUEL SYSTEM INCLUDING AN APEXI 1000HP FUEL PUMP, UPGRADED FUEL LINES, GREEDY FUEL RAIL, SARD 720CC INJECTORS AND SARD FUEL REGULATOR.
THE COOLING SYSTEM INCLUDES A 600x300x75 PWR INTERCOOLER AND AN EARLS OIL COOLER AND FILTER RELOCATER.
THE EXHAUST SYSTEM IS A TRUST 3.5 INCH ITEM AND IS RELATIVELY QUIET. I ALSO HAVE A SCREAMER PIPE (NOT FITTED).
DRIVELINE CONSISTS OF ‘98 SPEC 5 SPEED GEARBOX, OS GIKEN TWIN PLATE CLUTCH, 2-WAY MECHANICAL DIFF FRONT AND REAR, AND NISMO SHORT SHIFT KIT.
SUSPENSION INCLUDES BRAND NEW TEIN SUPER STREET COILOVERS, FULLY ADJUSTABLE CASTER RODS AND TOP CONTROL ARMS, WHITLINE SWAYBARS, APEXI STRUT BRACES, HKS SUB FRAME SPACES,
INTERIOR IS STANDARD WITH MOMO STEERING WHEEL, TRUST GEAR KNOB, HKS BOOST GAUGE, HKS OIL TEMP,CD PLAYER, BLAUPUNKT 6 INCH SPLITS, BLAUPUNKT AMP, PIONEER 6 INCH 2-WAYS IN REAR SHELF AND ALPINE 12 INCH SUB IN BOX. CAR ALSO HAS AN ALARM AND IMMOBILISER.
IT WOULD BE VERY DIFFICULT TO FIND A BETTER DRIVING R32 GTR AROUND WITH NO MORE MONEY TO SPEND.
REGRETFUL SALE.....$36K OR BEST OFFER.............PLEASE NO JOY RIDERS, THE CAR IS VERY CLEAN AND QUICK. FIRST TO DRIVE WILL BUY! CALL NATHAN ON 0402 777 201 IF INTERESTED.
Edited by Manu
https://www.sau.com.au/forums/topic/143498-1994-r32-gtr-for-sale/
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
