I have been looking into 2.8L kits and it seems to be slightly slim for choices.
The tomei kit is not a full counter so i have ruled that out.
The hks step 3 is the only one that i am highly considering for 2.8's
Now i had a question as to how would the Nismo 2.8 gt crank hold up in a high hp application.
I have been reading about a company who ran the stock crank in a 1000hp car and did well over 44 dyno pulls and numerous 1/4 mile runs. This makes me think that the 2.8 gt crank would be as strong as or stonger but i have not seen it being used.
I have also been looking at the trust 2.7 full counter kit and the tomei 2.7 full counter.
I will not go OS 3L :D
Any help would be great.
https://www.sau.com.au/forums/topic/143513-28-options/
  • Replies 50
unless you want massive power then you are setting your criteria far too high. a step 1 or 2 HKS kit will hold plenty of power. It's only if you want the massive revs and massive power that you need even consider the step 3 kit. The tomei 2.8 kit is also fine for most hard core street/strip cars. In japan at the moment it seems the HKS kit has the slight edge on popularity though. They are both around the same price, and in my eyes good value.
https://www.sau.com.au/forums/topic/143513-28-options/#findComment-2677163
as stated what is the purpose of the engine?!
stock crank and rods can handle 800hp (while given not indefinitly!), so any of the aftermarket cranks you mention should be fine. the step 2 HKS kit is ~800 rated, and as this rating is very much more than likely conservative, im sure if your building a street car that it will handle 1000.
Either way it sounds like fun, my HKS step 2 is nearly done!
Edited by SLY33
https://www.sau.com.au/forums/topic/143513-28-options/#findComment-2677301
I guess i should have worded that better my bad.
I am wondering what other kits are available and if anyone knows wha tthe nismo 2.8l gt crank can take power wise.
Crower's 2.9l will be out shortly in the new year.
I don't know if Apexi is still producing the 2.9L
The build will be tracked at around 1200 bhp and ran around 800bhp most of the time.
Edited by icydude
https://www.sau.com.au/forums/topic/143513-28-options/#findComment-2677948
For the money.....
Would it not be wiser to spend it on a 3L bottom end , a set of oversized forged pistons,cams and
a decent head port?
I Find these kits to expensive.
What modes do you have and what power figures are you looking at?
:P
https://www.sau.com.au/forums/topic/143513-28-options/#findComment-2679177
The problem with the RB30 blocks is that unless you spend big dollars on a decent crank, they will explode at around 7500rpm.. my mate has a twinturbo twincam RB30 which he is pulling out to replace with a HKS Rb26/28 stroker.. so he can rev it to 10000rpm :D
https://www.sau.com.au/forums/topic/143513-28-options/#findComment-2681179
u dont need to rev them (rb30) out to make big power, as they make the same power as other kits at lower rpm. plus u cant go expecting to rev a standard crank to nything near 10k like u could do with say a HKS, caus the HKS is full counter-forged, its like comparing apples and oranges
my rb30 is pretty much finished, im just waiting on the sump and my adapter plate to be ready (i've made my own adapter plate)
https://www.sau.com.au/forums/topic/143513-28-options/#findComment-2681274
to make big torque or big power? as horsepower is a function of torque and revs, then yes more revs = more power..
and what exactly is "counter-forged"? do you mean they are forged and counter-balanced?
torque wins races, horsepower sells cars :wave:...no1 wants a big power street driven car that when they smack the go pedal they gotta wait 6000rpm to go anywhere
and yes, i was being lazy :D
https://www.sau.com.au/forums/topic/143513-28-options/#findComment-2681410
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
