I got my aircon topped up the other day (R33).
The guy stuck a thermometer into the vent and left it there while he gassed it up.
Before top-up it was showing 12 deg at the vent. After he'd finished it was showing 4 deg.
Obviously this is an improvement. I'm just wondering what temps others get at the vents.
as if there's bikini babes :no:
now gimme answers.
Edited by Munkyb0y
i guess if it's blowing cold air, but not cold enough, you probably need a regass.
if it's not blowing any cold, then maybe something else is wrong.
whoever you take it to should be able to tell you.
mine was just a top up, and it seems fine now.
Air con will lose a little gas each year and should only need to be topped up every 5-7 years from memory. If you are losing alot of gas and need to top up frequently then there is a leak there somewhere!
Its blowing cold air, but could be colder I guess, my brothers Toyota is really really cold!
How much is a regas? should try to squeeze it in before the start of summer.
cost me $70 for the top up.
Anyone know a good places in the bankstown/st george area for a re-gas?
yeah, the guy i went to is pretty good. he doesnt stuff around.
he's on canterbury rd, at hurlstone park. auto electrician, just a bit down the road from hurlstone park rsl, opposite a service station.
tell him tony with the black skyline sent you.
Edited by Munkyb0y
Sounds good mate thats not too far away. You wouldnt happen to know the exact address or a phone number would you? I might have to get mine topped up, if today is anything to go by this summer is going to be HOT.
Edited by R3LOAD
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
