Hey people, jut letting you's know that my life officially ended today. This morning at 3:40am i woke up to the sound of my car driving down my street, at first it didnt click a minute of thinking went by n i thought to myself, i've been living there for awhile now n dont know of any skylines that drive down my street. Thought i'd go check on it for peace of mind and sure enough there was a blank space where it was parked. It was parked on the front lawn facing the house. No broken glass was left behind, no evidence what so ever. I even had the battery disconnected for that reason but they found it and managed to bypass my immobiliser n start the car n drive off. Its so not cool, and i only had 3rd party fire n theft insurance so max payout from just cars 3rd party is 5k. along way off what i had in mind for the car but u cant help bad luck hey, be careful with our cars guys n gals
https://www.sau.com.au/forums/topic/143556-stolenrecovered-red-s1-r33-gts-t/
tough break. hope you find it. my mates series 5 rx-7 got stolen the same night he sold it. 1.5 weeks later cops found it dumped in richmond. hope yours was a joy ride like his was.
i always ask this question though, did you have a club lock?
Edited by (B1) MR_fanny
hi guys, its a series 1 r33 gtst, its had a custom respray red, 17inch bbs rims, has a dmd lip spoiler on bootlid, m spec front bar with the middle chopped out with a front mount as exterior noticeable parts. 838 HGO is number plate, on gold coast, car was stolen from coomera. cheers
I'll keep an eye out 4 u......I go to alot of houses due to work and travel all over the coast. Will let you know if i see anything.
ah sheet...sorry to hear the bad news mate...hopefully it'll turn up somewhere once it runs out of gas...
bit amazed that they went through the trouble of locating the immobiliser AND checked that the battery was disconnected...must have stalked u for some time and observed u doing it
Shit man, that sucks.. sorry to hear it. Hope those mofo's leave the car intact and in one piece, hope it gets recovered soon.
Thief's are the lowest mofo scum bags... hope they get punished, hope they receive a slow and painful death.
Edited by pretender-
stoopid mofo's prolly wanked off dreamin of a skyline but was too shit lazy to get a job and save up to buy one!!
must say that they sure know how to pick their ride tho...sweet lookin car mate...or rather ex-car (not rubbing salt on wound)
I would have a drive around your immediate neighbourhood and have a GOOD look at peoples yards,under houses etc.. sounds like they might have been watching you for a while...
see if your neighbours heard/saw something, have any suspicious cars been cruising around your area?
still it doesn't look good for you mate :)
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
