Hey all,
For sale is a surge tank setup with a Genuine Bosch 044 pump and all fittings needed. The tank is a 2L polished RPM EFI unit with 3 dash 6 fittings at the top and one dash 8 fitting at the bottom for the pump to feed off. The fittings on it are the Proflow Engineering fittings and the pump also has its own anodised bracket.
Everything here is brand new and unused, only pulled out to see what it looked like!
All thats needed to get this setup going is a bit of hose and 12v!
NOW $500 for everything here, im also willing to separate but prefer not to.
Located in Melbourne, I dont mind posting.
Thanks!
Mat.
0400 558 030
Edited by femno
https://www.sau.com.au/forums/topic/143583-surge-tank-and-044-pump-setup/
  • 1 month later...
  • 1 month later...
Sorry for a possibly dumb question but what will a Bosch 044 pump flow Hp wise. I need 600hp pump at least for my current application.
Thanks
The 044 will flow up to around 600HP as far as im aware, maybe a little more. This setup is a must for any highly modified vehicle to eliminate any possiblity of fuel starvation.
044 for sale: click my sig link.
All still available.
Hey. I am in the United States. I have calculated shipping costs via EMS from there to here. I will give you $575 AUD shipped to me for it. I have money in hand and can pay by what means you prefer. Thanks for your time.
Edited by Ramius83
  • 1 month later...
Do you have any more info about the surge tank? Manufacturer / Model?
Yes it is an RPM EFI branded surge tank, 2L capacity with dash fittings. Polished Aluminium.
  • 3 weeks later...
  • 1 month later...
  • 5 months later...
  • 1 month later...
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
