well thanks for deleting my other post
the explanation given for the dead turbo from ( forum sponsor ) was insufficient oil supply ( yeh right )
lines were ok he says as he made me send them but he blaming my engine which is the tightest rb20 anyone has every seen and has oil changes every 5,000klms and also uses slick 50
always an excuse on their behalf,,
asif the bearing didnt faill then there was lak of oil cos it was in my exhaust
so no warranty wat a suprise
after paying for the turbo waiting 8 weeks saying it was direct bolt on then the day i receive it a write an email sayin the wastegate did not seal was atleast 1-2mm gap from housing, his explanation oh after 2 or 3 power runs it will seal up yeh rite ! and that day then telling me my oil lines need modyfing wtf
everything was done correct everything, so lets blame the engine to void warranty, even thou the engine has never had 1 part fail ever and was running great until the turbo change..
what a sponsor hay
Edited by bbe
https://www.sau.com.au/forums/topic/143586-brand-new-turbo-dead-forum-sponsor/
  • Replies 167
Posted Images
is there no offer of parts warrenty? im not sure of the condition of your motor etc, but i did remember u stateing that u went gcg and other turbos, all failed, now u put on a slide turbo and it failed also, the slide is the 3rd-4th turbo fitted, id be looking somewhere else also :), this is the first failure that ive read about on a slide turbo failing. im not taking sides, just giving an outsiders opinion
I think it only right for me to show the report given on the turbo in question.
I do not appreciate threats and public defamation.
This is the first failure of its kind in over 800 highflowed turbo's.
The only other failure on one of these highflows was a faulty thrust bearing and the turbo WAS covered under warranty for a member on this forum.
The cartridge journals are bronzed.
This tells me that at one stage there has been no oil surrounding the bearings and caused the shaft to spin the bearings with no oil in them and has sheered off a layer of metal from the bearings and bruised the inside of the cartridge.
The shaft is bruised and where the bearings lay you can clearly see in this picture that they are scortched.
This is the result of no oil being fed into the bearings or could have been the result of reving the engine alot before the oil preasure has built up for the first time and starved the bearings.
There is also scoring on the shaft which would suggest dirty oil.
The bearings are scortched and bruised due to the lack of oil as you can see in this picture.
Both bearings are the same.
The Thrust is completely shattered and has spun.
This is caused by no lubrication.
The bearing oil collars are all fine so if the oil was being fed into the turbocharer there would have been no problem.
On all turbines we use a Z or zero gap oil ring.
This is purple in colour now and also sugests no oil lubrication.
The housings can still be used after a bit of machining but the entire cartridge setup has been destroyed with the wheels and shaft.
I would think that the only reason your current turbo is alive is that it is ball bearing and does not require great oil preasure to lubricate the bearings.
The failure of the turbo is not the cause of faulty internals or assembly of the turbocharger and subsequently not covered by warranty.
Postage of the item was paid for by myself and was specified to be delivered by registered post.
The repair costs of this turbo is $500
Aaron
is this the third thread about the same issue now? your other threads where not deleted, they were closed. you were blamming the fail on th turbo before it was even tested
Everyone who is trying to blame an engine failure on some one else or some thing else always says there engine was the best and they took the best care of it blah blah blah. Sure you may have taken care of it, we cant prove you didnt.. But if this was all because of the turbo, why is yours the only one thats had a problem like this, I think all the feedback that has been given to slide in threads and in his feedback section shows that you cant sit there and blame him for this..
with the amount of money aaron has made from the quality and success of these turbos, i doubt hes trying to jip you for a lowsey $500...
Sorry, i really didnt want to have to say this, but.....
Has it been rebuilt lately?
How do you know its "Tight"?
Motors fail. Thats life. And things break. Dont believe me?
Read this thread
http://www.skylinesaustralia.com/forums/in...st&p=944864
I had an RB26DETT fail, which was warmed up and cooled down meticulously every time its driven by me and the last owner, and guess what? It wasnt showing ANY sign whatsoever of imminent failure before it happened. Engines dont last forever. Now you're probably going to tell us your car has a genuine 50,000k's or so, never thrashed, and was well looked after in Japen etc.
But i dont understand, you said at one point you were a paid mechanic?
Do you seriously not understand these things need PROPER lubrication to stay working unlike ball bearing?
You know how i know you're wrong there?
Your turbo is in bits, with burn marks from lack of lubrication, and there are over 800 working without issue.
Come on seriously, take a step back, you've had a number of turbos fail.....public slandering of the maker wont help you get this fixed.
as fot the other turbo failing this was 3 years ago on another car fitted by sum1 else so yeh
my car must be fair healthy to rev to 9500 every day on 17psi constantly and has done 60,000klms with me driving it this way
yes woh he bearing looks like its had lak of oil---how about the bearing was faulty crapped itself and had lak of oil due to it all going out my exhaust
no that couldnt be the reason
and $ is not the point all thou it was not $500
well if he is such a champ lets see if he refunds the postage as he says
and yes i would like my turbo back and my useless oil line as it will be going to bill from ats !
seems its ok to bag a person on here but not a sponsor hay
freedom of speech
only my miss fortune thou hay
pls send turbo back as i atleast get what i payed for and Consumer Affairs need me to get another report i dont care if they do nothing aslong as they are aware of this matter !
"my car must be fair healthy to rev to 9500 every day on 17psi constantly and has done 60,000klms with me driving it this way"
would it be as healthy as u think, if thats how u drive it?
seriously give up, u stuffed up plain and simple..consumer affairs lol what do u think there gonna say when YOUR turbo has been the ONLY one thats failed...ive been through them many times, i cant see them doing u any favours in this situation
ben...
Edited by 2BNVS
^^^^ thats hilarious 60,000klms has not missed a beat was stating a point by it nor does it use any oil at all,,it has been rebuilt properly !
that aside omg i rev my car so it has no oil pressure for the turbo wtf a lame excuse seriously
and as for slander, well actually it cant be classed as slander on a public forum like this..
slander is only wen you do it in obvious public places eg. owning your own tinting business and on your adds and business cards saying "we are soo better then johns tinting"
the whole "slander" angle is used to scare people into not saying bad things about a company or product.
just like you going to consumer affairs and telling the company that you spoke to them, its just tryin to scare them.
seriously, get a legal dictionary and look up "slander / deformation of character"
i mean sure, they COULD take you to court for sayin stuff on here, but if you have even a half decent lawyer or judge, the case would be thrown out.
peace
peace
http://www.skylinesaustralia.com/forums/in...?act=boardrules
that turbo has clear markings of oil starvation.
I had a turbo fail for exactly the same reason...
Cause, low oil pressure on the car, not enough oil to the turbo, turbo starvation and the blue marks on the shaft are a direct result of poor oil supply.
freedom of speech
Rubbish. No freedom of speech here mate.
Read the forum rules you agreed to when signing up here
No slander to be made towards businesses or individuals. We understand that if you have had a bad experience with a business you want to warn other people of said experience, at the same time any information that could be classed as slander or is an attempt in anyway to deter business from any individual or business on this website is the responsibilty of the owner of the website and all legal liability falls on said owner
Have some warning points and a 2-day post ban.
You wanna slander a business and go against the rules, its timeout time for you
Cheers.
Deform, awesome. I'd get deformed into a ninja! WOOT!
Also, slide does good work. Mate of mine got a highflow a while back. Hasn't missed a beat and his car looks stock.
It sounds like you didn't hook it it correctly, it's not a stock turbo and clearly states the extra work involved. Looks like you should just be quiet and deal with this in private as nobody here is going to support you.
Guest
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end a made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
    • As someone who has pineapples, and horrible axle tramp... should I change these to collars? Is that what you're saying here? Why did you choose these instead of getting pineapples where you said you had good experiences of? I'd love to even attempt to get rid of axle tramp, I either get complete bogginess or absolute insane wheelspin, anything even remotely in between results in filling-removal axle tramp, to the point where launching the car is just not something I do.
    • Lucky for that, because putting ethanol in fuel only lowers the bulk cost of fuel if it's in 91 Add it to 98, 85% of it even and it quintuples in price. Strange physics. f**k you United, Gouging c***ts.
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
