  • Replies 167
Posted Images
As I mentioned in a previous post.. People wouldn't have stirred and had some fun at his expense if he chose to deal with the situation as an adult.
But more to the point...... He still hasn't got back and stated how his oil pressure situation is on low rpm and idle.
So until he starts to try and work through what it may be with an open mind he will continue to have people poke sticks at him.
He should take it on the chin like a man and get back to us. Shit happens, its as simple as that.
well im a mate of bbe's and well he knows his shit seriously the most well looked after rb for sure thing goes hard day in day out you's just all baggin the f**k out off him is pointless as you could seriously learn a thing or ten of this dude much like my self id like to see any rb25 keep up with this rb20det seriously
Might want to get your engine checked too then :)
aquariuz6,
Out of curiosity whats the going price for a decent removal/install?
Hows your low rpm idle pressure once the cars warm?
Hey cubes HITMAN quoted me before, I think it was around $220. Can't really remember.
But I just want to save up so I can send it back to Slide afterwards, then get the HITMAN guys to install it.
Atleast this time it will be in good hands.
About the idle... actually its quite exactly the same as stock.
Does idle actually have anything to do with the turbo being seized?
One thing for sure is that, the turbo does get very hot as usual. Although I don't hear the loud spooling sound like a jet engine anymore like it was when installed.
Plus the fact that my boost gauge only goes up from -7 to 0 nows while driving. It just seems that it won't let it go past 0. Car runs like a pig.
he's ip banned
no he isnt
you are a funny guy, no... seriously
You may want to get him to remove the engine then and get it acid dipped, to remove the f'ucking teflon, from his fu'cking oil galleries!
Nah didnt you know, its a trademark RB20 secret bro... get the tacho needle spinning around to hit the clock and your at 9500rpm... just make sure the flux capacitor is working and where youre going, you wont need roads!
my car must be fair healthy to rev to 9500 every day on 17psi constantly and has done 60,000klms with me driving it this way
I doubt it
Prima facie its not
Man is this thing still going...for god sake wont someone stick a fork in it
well im a mate of bbe's and well he knows he's shit, seriously the most f**k'd rb for sure thing goes hard day in day out you's just all baggin the f**k out off him is pointless as you couldn't seriously learn a thing or ten of this dude much like my self id like to see any rb25 keep up with this rb20det seriously
A push bike goes faster than a car with a f**k'd engine and no turbo mate! LOL
Guest
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
    • Yes, important point. Watch the Motive videos with Herman thickness testing the bores and deck. You do not want to push the unlucky (thin) block as hard as you can push the average block.
