What I do, is when I get out of the car, instead of just going ahead and touching the metal and getting zapped, I hold the key near the key hole. You see a little spark, and you don't get zapped.
For you to get zapped, the point of contact with the metal needs to be a part of you.
I was told the tyres rotate and pick up charges or something like that and that was the cause.
Maybe it is my clothes....I'll try cotton tommorrow and see if this works.
Also, this looks like it happens to every-one then? :rofl:
When you open the door, keep a hold of it (As if you would if another car was parked closely) but hold on to the END of the door, so that you're touching metal, then stick your foot on the ground. No more zappy...
I have to get back into this habit...
Both my cars have earth straps (Can't see them though) so I got out of the habit, and now I get booted in every friends car!
So the answer would be to get a rubber strap :)
Surely we can give an electrical discharge circuit to the front seat so we don't pick up this static....
Is the solution that easy though?
Think....your not just on here to check other peoples avatars are you? :)
Could you run a rubber strap from some part on the chassis onto one of the tyes? They're grounded, and you wouldn't be able to see the strap if you positioned it well
Good thinking there...except it does not have to be on the tyre all the time ......just when you open the door.
Maybe a pulley type ...simple set up that operates on a wire connected to a rubber?
Maybe to much over-kill.....
STILL LOOKING. :P
If we come up with an idea...we will patent it and make lots of money :D
Something i saw other day on youtube was quite disturbing, involved static electricity a car and a petrol bowser.
Overkill is great, as long as people buy it.
Could just set up a servo to automatically reset itself to off position (which would be facing down, at the tyre) whenever the power is cut to it, my old remote control car used to do this once turned off.
The only trouble would be for a Turbo Timer....It would have to be when the door is opened.
:P
We are getting some where :sorcerer: :sorcerer: :sorcerer:
The factor is, the type of rubbers in the tyre doesn't allow the car to discharge at all.
Well, actually, if you notice, it's normally the spark jumping from YOU TO the car...
This tells us, the electrons (The part of moving electricity) is moving from person, to car.
Hence, we have more electrons in us, then what the car has.
Hence, our body has more electrons in it.
What this tells us, is the car is actually insulated from earth.
Hence, we are moving electrons from the earth/us, back into the vehicle to create an equalisation
Hence, when you jump out, and make a connection, you get zapped.
BUT, if you connect to the car first, and then connect to earth, you don't feel your foot being zapped (Due to large surface area etc)
Hence, GRAB THE CAR FIRST, THEN step out.
Or, fit an earth strap. My R33 has a strap, and you can barely see it at all, unless you look under the car.
Why bother making something new and expensive, when there is a cheaper, easier alternative available.
To many Hence.....in your report MBS206.... :D
Still am not giving up...a strap looks like your driving a Camry(Not that they are bad cars) or something,
What you are saying is the electrons charge us in the car as we are driving.
When we go to exit the car without dis-charging these back to the car, we get zapped.
If this is correct why don't we have a car earth on the door handle.
Is it that simple?. ;) ....maybe not. :D .....is this the cure? :)
Or is it more simple than that? :laugh:
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
