It now looks like I have a leak in my exhaust manifold gasket. GRRR.
So, does anyone think I can remove the manifold without taking the lines of the turbo?
My plan was to:
1. undo cat at front
2. take off intake piping
3. unbolt turbo from manifold
4. Take manifold and shielding off, holding turbo in place
5. replace gasket
What do you think?
https://www.sau.com.au/forums/topic/143635-taking-exhaust-manifold-off/
Depends, are your lines hoses/braided etc or std steel pipes. if steel pipes, no chance, if hoses then I'd reckon it could be done, I'd lower the turbo down and out of the way then it would be easy.
The good part about it is if you bend one and it snaps or fractures, you can replace them with braided lines and then you'll never have to worry about whether it can be done like that again...lol
For the 4 bolts involved + dumping your coolant, I reckon it would save time and swearing/knuckle grinding just taking the turbo off. Plus you will have more room to move the mainfold etc.
Edited by Lazy-Bastard
Just take the turbo off. Its 'only' 4 nuts and a couple of coolant lines. Adds another 30minutes on to the job IF you have the right tools. :D
At least then you can get in and clean up both surfaces correctly.
Its also difficult to torque up the exh manifold nuts correctly with the turbo on. Do use a torque wrench unless you want to be replacing another gasket + studs later down the track.
Their torque values are up surprisingly loose.
just take the pipes off and replace the oil and water at the same time..:(
When the turbo came off mine,in a similar situation to you,i found that the banjo bolt for the water line was calcified over closing off the flow of water of into the turbo significantly.So you might be able to avoid a future problem there.
More so on a stock turbo than an aftermarket 1 with new connecting parts.
I've found from experance that by trying to short cut doing something on an engine instead of doing it properly tends to make the job twice as long and often in the end you will have to do it anyway just waste time trying to short cut it ,but there are always exceptions to the rule good luck
cheers Peter
You learn as you get older "do it once do it properly "
I have found it easier when removing a manifold to just undo the manifold leaving the turbo bolted on unbolt the oil and water lines and lift the manifold and turbo out together with my hks manifold I usually unbolt the engine mount under the manifold jack the engine up a little as well ,makes it a little heaver when removing but this has always worked well for me
cheers Peter
if you think you blew the manifold gasket, i would remoove the turbo and replace the turbo to manifold gasket aswell just to be safe, as those nuts/bolts generaly rattle loose and then you have a blown manifold to turbo gasket 1 week after replacing your manifold to motor gasket.. just my 2cents
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
