if it comes in the kit, then probably. make sure you check if the dump pipe mates up with the stock one.
but as soon as you fit, youll boost it up, hit r&r and then youll post up why your car runs like poo. so best you do some research on all of the mods you will to make it work correctly and get the best out of it.
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2680426
if it doesnt come with lines, you will have to make up new ones and a silicon elbow off the turbo to the intercooler pipes. Also depending on the size of the front cover you may need to make a new induction pipe...
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2681062
I already have everything nessary to run the turbo just wanted to no if it would fit with out to many problems so it shouldnt r+r as i dont have the stock computer and yes i know ill have to tune it just wanted to know about the fittment thats all
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2681108
Well in that case yes it will bolt straight on there, as my 3037 pro s did, the only thing you will have to worry about is the dump pipe/front pipe to cat position and most likely going to have to custom on, part from that good luck, i think thats the answer you were after?
and of course you do know that you have to change the lines part from that it does bolt on
Thankyou
adam
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2681485
Just wanted to know if a hks 2835 pro s will bolt straight up to a rb 25 ?
if you buy the kit!
it comes with everything you need.
also it doesnt need a gasket from the turbo to the dump, i went around in circle with hks tring to get one, 1st they sent me the wrong 2 gasket then in the end they finally said OHHH GT2835 PRO S that doesnt need a gasket at all ahah!
awsome turbo i see full boost under 3500rpm
umm mine come with all lines (braided), metal intake pipe, silicon thingso and also the elbow from the turbo to the i/c (also inc silccon thingo and i little clamp which has like a heatshield over the silicon joiner thingo) + a nice hks heat sheild
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2682062
' date='17 Nov 2006, 10:24 PM' post='2682062']
Mine doesnt really hit its swing till 4grand. what boost are you running? I think mine can see 19psi by 4grand, then falls to 16-17. Although you can really feel the torque coming on just after 3grand.
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2682972
im only running 16psi with a very very safe tune (11:1 afr)
i want to do headgasket and cams and increase the boost to the 18psi see if i can come close to 400rwhp
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2682985
As everyone else has said, they are a great turbo, Brought the kit. Straight bolt on with no problems what so ever. Have just fitted cams and Plazmaman plenum. Have to go an get a tune asap.
Edited by woolls
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2683353
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
