YAY!!! :blush:
Glad your going to grace us with your presence Sav!!! It's been ages man!! You can headbutt dane in the ovaries for me!
It's one of the reasons I'm coming! :D Joe, Matty and maybe Rob will be joining me too. It'll be 4 doors galore. :)
  • Replies 83
Just push it Dane... or kick it! Either way I'll have a giggle! Ill see you all there!
I shall front kick it until it wins every award...
or just front kick everyone elses blue S15 with white Advan RG's
My ovaries are burning... :D
i can rock up at 10am, but i start work at 1:30, is it ok to just turn up for that amount of time? I work in south melbourne, so would be leaving about 1:20'ish...
any rough ideas at this stage when the awards will be awarded?
It's one of the reasons I'm coming! :) Joe, Matty and maybe Rob will be joining me too. It'll be 4 doors galore. :(
Saw Rob, Matty & Cabana last night they said they will come down for a look, they need to be members or sign up as members on the day to have there cars entered.
See you Sunday!
See you Sunday!
f**k damn shit! I have to go tho Sydney this weekend! Totally forgot! Got reminded last night! I swear, I'll make to a meet one day! :)
Trophies will be awarded in the following categories:
Godzilla class (best 32, 33, 34 GT-R)
Godzuki class (best 32, 33, 34 GTS/GTT)
WRC class (WRX, Evo)
Dorifto class (Silvia platform)
Intruder class (other cars)
James
What....No 4 door class........................Just kidding
I will be there..see ya all there
Just enter it and put it off to the side, at least you get free parking :huh:
Thats the way i see it, ill probably bring the two tone shlappa down, we all know its not that pretty, but meh. this is one thing i dont think i can beat Claw at, so i am hiring a trailer for dane :P.
sif i could afford to hehe
People entering
We ask that you arrive between 10 and 11am to make things a bit easier for us.
There will be marshals at each key point to direct you where you need to go. Maps attached below, but basically...
1. Coming from Richmond
Drive city-bound on na na na na na na na an - Batman Ave, under the TOLL until you see the marshal at the access road on the left (just past the intersection).
2. Coming from CBD
Drive Richmond-bound on Exhibition St bridge to the traffic light intersection where the tram turns. Turn left at these lights and do a u-turn to turn right and head back to the city. There will be a marshal here at the lights. When the lights are green, travel across the intersection and enter the access road to the park.
MAXIMUM SPEED IN THE PARK is 10km/h
PLEASE USE YOUR HAZARD LIGHTS WHEN MOVING INTO THE PARK
There will be a marshal just before the display area to make sure no bikes come flying down the ramp into your car. You'll then be directed to where to park your car on the gravel section.
This will all make sense when you get there ;)
If you are running late and the marshals have left the access road (not before 11.30am) - then please call me - 0417 037 520 - so we can remove the barrier and let you in. The barrier will have an SAU sign on it so you'll know where to go.
There will be a BBQ from about 12pm onwards - and all merchandise will be on sale.
It promises to be a great day - so bring your friends and a camera!
See you there
James
Guest
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
