Hi,
Ive recently purchased SydneyKids group buy bushings (front and rear camber kits, and Front caster kit). And am in a bit of a pickle lol :no:
My usual mechanic that i use for installs changed his number so i cant get hold of him (names Ryan owns a Silver 31 Aus spec with import spec parts on it) anyway, so i need to install these bushings however i still live at home and have a 2 car garage with 3 cars so we are limited on space so doing it myself at my house is impossible really unless i wud be able to get it done in under a day which i dont think i wud as i wud take it slow. Anyway, im wondering if anyone on here, having done THIS KIT before, is willing to install them for me. I can assist but having not pulled the control arm apart before unless im instructed to exactly do things, then it would take me alot longer.
Obviously I would pay an amount which (whoever it may be) and i thought was fair. Id ratehr do it this way instead of taking it to a workshop as this way at least i can learn as i go along should the time come where i need to do it again or need to help someone in the same position.
Any help would be greatly appreciated!
Cheers, David
I was looking at the bush kit a while back for my 33 from SK (I still need to get them) & he told me when I enquired that most of the bushes are a press fit.
You need a 10,000 pound press to be able to get the old bushes out & the new ones in so not really a back yard job unless you know someone with 1 of these.
Mate, call Ryan.
His number is now 0401 727 440
R31 silver, yeah, awesome lad hey, he's my mechanic too !! Did the first install at my home (sydneykid suspn) and this lot we are doing at his place down south. In fact, today's work got shifted to tomorrow. Doh. Lol, all is good: he became an uncle late last night! Congrats.
On my Stagea tomorrow we are fitting a highflowed Slide turbo, front and rear braided brake lines, front slotted rotors, new pads, auto oil cooler kit, oil filter, fuel filter, oil sump drain valve..... got an adjustable exhaust cam gear wheel and the front whiteline caster bushes but dont think we'll have time for these.
The whitelinefront castor kit needs a 10T press to push them on. I reckon I'll get these punched on when I have the 4wd Stagea wheel-aligned over xmas. The camber kits Im sure Ryan would have no trouble with.
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
