G'day all,
I Just installed an exhaust temp gauge in the car, but i cant seem to get it to read past the base number (500 degrees C).
Just wondering what sort of temps i should expect from a fairly stock R33, i had the gauge reading up to around 650 with a gas match under the probe, so it works as far as i know.
Also the probe is installed in the turbine outlet of a split dump, just in front of the oxy sensor.
Any ideas?
Cheers, Bart.
https://www.sau.com.au/forums/topic/143683-r33-exhaust-temp-range/
Stop-start city driving between lights (not just sitting extensive idling) 500-550C
Extensive idling 400 drops to about 350
Steady state rolling on/off throttle to stop, up to 80km/h not running big throttle 550-600C
Highway running extended closed loop running 600-680C
Climbing mountain range, mild boost 600-650C
Flat knacker acceleration run 700C
Thermocouple placed in split dump, main dump from turbine just behind O2 sensor.
Some of the cast HKS RB manifolds have a port at the collector , will get faster reaction times if placed before the turbo which does absorb some heat . Some tuning firms like to have them closer to the exhaust ports (by 6) and can help assist tuning on an individual cylinder basis . EGT tells alot about AFR but finding the variation between cylinders is impossible taken at the collector . The laser temp sensors would be handy at the tuning phase .
Cheers .
Can anyone tell me what the resistance of the sensor is cold? I'm hunting a problem at the moment and i'm leaning towards either dead sensor or damaged loom as i've checked everything else.
cheers
Dave
