G'day all,
I Just installed an exhaust temp gauge in the car, but i cant seem to get it to read past the base number (500 degrees C).
Just wondering what sort of temps i should expect from a fairly stock R33, i had the gauge reading up to around 650 with a gas match under the probe, so it works as far as i know.
Also the probe is installed in the turbine outlet of a split dump, just in front of the oxy sensor.
Any ideas?
Cheers, Bart.
https://www.sau.com.au/forums/topic/143683-r33-exhaust-temp-range/
Stop-start city driving between lights (not just sitting extensive idling) 500-550C
Extensive idling 400 drops to about 350
Steady state rolling on/off throttle to stop, up to 80km/h not running big throttle 550-600C
Highway running extended closed loop running 600-680C
Climbing mountain range, mild boost 600-650C
Flat knacker acceleration run 700C
Thermocouple placed in split dump, main dump from turbine just behind O2 sensor.
Some of the cast HKS RB manifolds have a port at the collector , will get faster reaction times if placed before the turbo which does absorb some heat . Some tuning firms like to have them closer to the exhaust ports (by 6) and can help assist tuning on an individual cylinder basis . EGT tells alot about AFR but finding the variation between cylinders is impossible taken at the collector . The laser temp sensors would be handy at the tuning phase .
Cheers .
Can anyone tell me what the resistance of the sensor is cold? I'm hunting a problem at the moment and i'm leaning towards either dead sensor or damaged loom as i've checked everything else.
cheers
Dave
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
