hey guys i got a R33 and evertime i try n change into 4th at about 4 thousand revs, so by the time u change its about 3500, the gear crunches, but it goes in, just crunches....just wanna kno wot i can do to fix it or it just goes away (doubt that, but u can always hope, lol). cheers for any advice guys :D
https://www.sau.com.au/forums/topic/143689-gears/
Could try chucking in some Redline Shockproof into the gearbox, of course, dumping your old oil first. I had a 1st to 2nd gear crunch and this seemed to fix it for me. Made my gear changes feel a lot more smoother too. Well worht it I reckon and should help you with your problem :D
https://www.sau.com.au/forums/topic/143689-gears/#findComment-2681432
The crunchin when changing gears is the synchros which require friction to work correctly. While redline shockproof is an excellent gear oil for protecting the actual gears in a gearbox it isnt the best for the synchros. Castrol VMX 80 gear oil is a better option. The are a couple tricks that can be performed to reduce some build up of material on the synchros and reduce glazing. First one is to fill the gear box with a kero oil mix and run the gearbox through the gears with the wheels off the ground so there is no load. Dont do it for too long as it will eventually where the gears. The second trick is with the gearstick in neutral, the engine running and the clutch engage apply pressure to the gearstick towards the problem gear. Dont push it so hard that it drops into gear. These will only provide minor improvments. Nissan gearboxes are renowned for synchro problems and the only true solution is to replace them
https://www.sau.com.au/forums/topic/143689-gears/#findComment-2681658
Nevernaughty..
I can say I've heard of the engine running clutch engaged and apply pressure to the problem gear.
I have recently started having issues with 4th gear when changing up from 6000rpm so I may give that ago. Failing that I will throw some synthetic castrol gear oil through it. The synth castrol stuff works well. :(
https://www.sau.com.au/forums/topic/143689-gears/#findComment-2681955
I thought that method was designed to "re-bed" the synchros. With the clutch pedal DISengaged, and the car at standstill, rev the enging to around 2000 and hold it there. Then pushthe gear knob down to fourth. It won't slip in.
I vaguely remember hearing something about doing it 20 times for 5 seconds, or 5 times for 20 seconds, but I cant remember which.
Disclaimer: You didn't hear this from me... :rofl:
https://www.sau.com.au/forums/topic/143689-gears/#findComment-2682215
My gearbox was fine, and after i changed my transmission oil with shell synthetic oil the following day my second gear started to crunch. I thought it was just maybe thicker oil than what was in before (dont know what was in before). I took to workshop and they replaced with lubrimax agritrans however it still crunches in the morning. Its weird how it just started happening after i changed my oil, it was fine before....
so should i just try a different oil ? is fixing syncros big job ?
https://www.sau.com.au/forums/topic/143689-gears/#findComment-2682276
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
