hey guys i got a R33 and evertime i try n change into 4th at about 4 thousand revs, so by the time u change its about 3500, the gear crunches, but it goes in, just crunches....just wanna kno wot i can do to fix it or it just goes away (doubt that, but u can always hope, lol). cheers for any advice guys :D
https://www.sau.com.au/forums/topic/143689-gears/
Could try chucking in some Redline Shockproof into the gearbox, of course, dumping your old oil first. I had a 1st to 2nd gear crunch and this seemed to fix it for me. Made my gear changes feel a lot more smoother too. Well worht it I reckon and should help you with your problem :D
https://www.sau.com.au/forums/topic/143689-gears/#findComment-2681432
The crunchin when changing gears is the synchros which require friction to work correctly. While redline shockproof is an excellent gear oil for protecting the actual gears in a gearbox it isnt the best for the synchros. Castrol VMX 80 gear oil is a better option. The are a couple tricks that can be performed to reduce some build up of material on the synchros and reduce glazing. First one is to fill the gear box with a kero oil mix and run the gearbox through the gears with the wheels off the ground so there is no load. Dont do it for too long as it will eventually where the gears. The second trick is with the gearstick in neutral, the engine running and the clutch engage apply pressure to the gearstick towards the problem gear. Dont push it so hard that it drops into gear. These will only provide minor improvments. Nissan gearboxes are renowned for synchro problems and the only true solution is to replace them
https://www.sau.com.au/forums/topic/143689-gears/#findComment-2681658
Nevernaughty..
I can say I've heard of the engine running clutch engaged and apply pressure to the problem gear.
I have recently started having issues with 4th gear when changing up from 6000rpm so I may give that ago. Failing that I will throw some synthetic castrol gear oil through it. The synth castrol stuff works well. :(
https://www.sau.com.au/forums/topic/143689-gears/#findComment-2681955
I thought that method was designed to "re-bed" the synchros. With the clutch pedal DISengaged, and the car at standstill, rev the enging to around 2000 and hold it there. Then pushthe gear knob down to fourth. It won't slip in.
I vaguely remember hearing something about doing it 20 times for 5 seconds, or 5 times for 20 seconds, but I cant remember which.
Disclaimer: You didn't hear this from me... :rofl:
https://www.sau.com.au/forums/topic/143689-gears/#findComment-2682215
My gearbox was fine, and after i changed my transmission oil with shell synthetic oil the following day my second gear started to crunch. I thought it was just maybe thicker oil than what was in before (dont know what was in before). I took to workshop and they replaced with lubrimax agritrans however it still crunches in the morning. Its weird how it just started happening after i changed my oil, it was fine before....
so should i just try a different oil ? is fixing syncros big job ?
https://www.sau.com.au/forums/topic/143689-gears/#findComment-2682276
    • Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
    • Try fabricating something like this and install it under the pedals? Not sure if it's legal or not....
