hmmmm, interesting???
jus read that the sonsor shud be on the top hose, mine came with the car wen i got it but its on the bottom hose, is there any logical reason why its there, wat difference wud the top and bottom make??
is it hot engine coolant coming out the bottom hose through the radiator and out the top cooler or the other way???
the top hose is generally the water coming out of the engine, so its a better representation of internal water temps. where as the bottom is water coming out of the radiator, which has been cooled.
wat wud u rather kno ........????
temp of hot water out of engine, to make sure its not rising too much inside there OR temp of cool water goin in the engine to make sure it is getting nice cool water.
the factory sensor is on the top hose so u already have the stock temp gauge there. i also got a oil temp gauge so in my case i'd rather know my radiator is working and sending in cool water to the engine.
anyone got other theories....
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
    • Oh, yes. If you connected it to the manifold your first drive would be very eventful. Very shit. Very interesting. Perhaps take a video if you feel the need to see. Terminating the breather at the top of the bellhousing is normal/stock. Some gearbox lubes (hello Redline Shockproof) like to foam up a bit and require the breather to be extended up higher, so you don't get spots of smurf jizz staining the floor under your car. Mine is thus right up behind the head. Make sure you fit a u-bend at the top so it points back downward so that dirt and schmutz has a harder time getting into it.
    • Cheers for the replies. So i don't connect it to the manifold I just run the hose high up on the firewall?
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
