Items:
Wanted R33 or R32 skyline
It can be:
A shell, unfinished project or with no motor and or gearbox
You car has engine problems and you wanna sell it
non Turbo r33 or 32
Or if you just wanna get 8 grand cash straight up for your skyline
Car has be fairly straight with good paint
Pay up too $8000
I have an Rb25 Engine and running gear just want to drop it into something
Contact Details:
call me on 0400285588 or sms but email me would be easier or add me on msn [email protected]
Items:
It can be:
non Turbo r33 or 32
Pay up too $8000
Contact Details:
seen a black r32 in last weeks trader for $7900, in good condition, even has a few goodies eg. cooler, aftermarket fuel pump... giv it a ring if your lucky it mite still be there...
Try the forum traders section, theres quite a few for sale in there
Thanks for that Damo, am aware of those.... Found some cheaper than that on Egay.... But would prefer to buy one of a SAU member to help them out.... Maybe even save some coin while im at it!
Im in the market for one myself, but new clutch, service and tune has cleaned me out for the time being. Personally i'd buy a new one, and you probably wont find cheaper than the specials in the trader section. Good luck!
WTB: Bride super low bottom mount rail suit R32 (4door if it makes a difference) preferably cheap as possible (unemployment doesn't pay much these days :banana:)
one fiddy @ jms for s13 one, drinkies can mod it to fit
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
