Hi guys, new member here :P
Currently in the market for an S2 (96 or above) N/A R33 GTS4. The car must be auto so that other family members can drive it as well. Have the cash ready.
Post what you have guys :teehee:
PS: Strongly prefer SA/Adelaide cars as this is where I'm located, cheers.
Tom.
^^ your kidding right
there is a R33 GTS4 1997 albeit manual in the For Sale Section not really hard to teach someone how to drive manual or do an auto conversion im sure someone with an auto box would be more than happy to swap
come to think of it dont reckon you will get auto and 4WD in the same car
<-- boot lock without the badge looks shite. still after 33 boot lock with swivel badge. S1 or S2 are fine
and also the plastic inner front guard liner that surrounds the standard SMIC to suit 33 S1 type M front bar
<-- the plastic inner front guard liner that surrounds the standard SMIC to suit 33 S1 type M front bar
i dont know if it will fit or not but i have the one off of my s2 33 sittin here if you want to try it
Hi Steve, thanks for your thoughts. I wouldn't mind a manual for a weekender, however, I will be driving the car in the city everyday so an auto would make my life much easier.
LOL
u gotta be joking, a manual is so easy to drive if you know wat ur doin, and u got more control over it in stop start traffic
and as madaz said, if u find a auto gts4 in adelaide, well damn u must be really good
its like finding a R33 GTR autech sitting in a elizabeth with the keys in the ignition lol, just aint gonna happen anytime soon
so just get a manual
LOL
explain how a manual in stop start traffic, has more control over an auto!?
:D
i am looking for a complete gts-t engine, low k's preffered, its gunna get worked anyways. looking in s.a owww and prefferably at a good price.
cheers... michael p.s its worth a shot in here. oww and mate i got a r33 gts-4 but its manual and a 94 great to drive, not hard to drive either, but when i first picked it up day 1 i bunny hopped it near morthetvalle and reynella was a classic.
hey mate, cheers! let me investigate that a little further. my mate has a S2, i'll have a quick look at his. If it looks the part, ill definitely shoot you a PM
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
