Wanted To Buy
Cubes
Items:
R33 series 2 steering column plastics, mine has super glue all over it just want a clean one, only require top part if that helps.
R33 underdash (has the fuse cover in it) don't know what else to call it.
R33 fuse cover plastic, series 2 if any different.
R33 original gearknob.
Contact Details:
0407 747 386
Or PM me
Price and price conditions:
Don't know how much these are but open to offers, will get rough prices and post up prices
Thanks
Brad
Items:
Contact Details:
0407 747 386
Or PM me
Thanks
Brad
have the steering wheel surround from a series 2 and i have the under dash thingo but im considering replacing mine with it
pm me an offer
I need a throttle body and throttle position sensor from a series 1 RB25, if anyone has one could you call me on 0423 277 771 or PM me on here.
Thanks! :D
i have a series 1 throttle body somewhere, not sure what the other thing looks like, post a pic so i no what it looks like
NEED RB20 COIL PACK LOOM ASAP!!!!!
PM PLEEEEEEEEEEEEEEEAAAAAAAAAAAASSSSSSSSEEEEEEEEEEE!!!!!!!!!!!!!!
go see wally at z imports. he might have one and cheap.
Its part of the throttle body, a little black connector with 3 wires I think on it, basically tells the ECU how far open the throttle is. How much would you want for it? I can come pick it up during the week or if you want to meet somewhere, would love to get fairly soon if you still have it. Thanks :D
Edited by Rolls
Looking for r33 S1 stuff:
-M-Spec front bar (black)
-factory side skirts (black)
-Rear bar (black)
-Rear pods (black)
-Drift wing (black)
3'' bell mouth dump or Screamer dump.
Also interested turbo upgrade! looking to make the mid 300rwkw.
Let me know.
Cheers, Kym
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
