Wanted To Buy
Cubes
awe thanks steve lol.....i am trying to get a second hand one atm....if i cant get hold of one then i will borrow yours.....i would rather buy then borrow if you know what i mean :blush:
cheers man really appreciate your help
want to buy parts to finish my track car have cash to pay for them this weekend or happy to pay postage
r32 gts-t NON abs master cylinder
Profec B boost controler
s13 rear pods, factory lookn ones to just smooth the factory skirts out
550cc injectors for SR20 if u have 6 out of a rb25 for the rite price ill still buy em
r32/ s13 rear toe arms
r32 gtr or similar boot spoiler
thanks every1
-Adrian 04 253 13 447
hey guys
i need the pipe that goes from the return intercooler piping to somewhere.....its near the stock bov...mine has a mad split in it and its leaking boost....i have attached a pic to let you guys know what i am talking about....
and i need it asap
i believe i have 1 as well you can throw an offer and its your's...
wanted!!! can anyone replace my heater core for my 34 plz will pay
Sorry to tell you mate, but is in an ABSOLUTE PAIN IN THE A$$ of a job, as the WHOLE dash needs to come out. I can't even imagine what it would cost for a workshop to do it. The R33 one is MUCH easier, as about 1/3 of the dash needs to be removed to do it.
cheers guyz well i just bypass the heater hoses for now just hav no heater now oh well as long as i have a/c. got second hand heater core waiting 2b put in so who ever can do it let me no!! cheers
you sure they cant get into it by the glove box
i forget how much would have to look up an invoice but im thinking around the $200-$250 with supplying a 2nd hand core
and then that core broke and it was in again at there expense, Rocco and Rob are champs
Yes I am 100% positive Steve .... given I tried to do it. You can't even get close to the core getting out/in from behind the glove box. In fact even with the whole dash removed and the structural steel mounts loosened I still couldn't get the whole heater core with shroud etc out and had to break a bit of the plastic away to remove it and install the new core into the old shroud/mount/box.
But yeah, try Sinergy for a quote - maybe they know a secret way to do it.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
