Wanted To Buy
Cubes
Just wondering if anyone has a wrecked engine i can steal one from, coz i cant get to Nissan to get a new one...
I need the rubber grommet that connects the hose to the rocker cover on the drivers side cover (in the middle of the cover, plenum side).
you can see the hose in this pic
circle it and i might have it
rb20det or rb25det gearbox
send me offers on either
must be in great condition with smooth shifting and no crunches or noisy synchros
pm me with what you got
RB20 Gearbox, in Adelaide $500
R32 stock drivers seat and rails not sure how to describe my tri
photos are probably the easiest! Cheers Jamie
PM sent
WTB: series 2 R33 aftermarket GTR style front bumper preferably in white. If its a different colour it dosent matter if its craked as I will fix it and repaint. Let us know what you have thanks.
Got a Rb20det inlet cam out and ready to go $30 and its yours
I work near Parafield
I would have PM'd you address but i need to have 10 posts to PM
Txt me on 04 3968 3619 (dont call as speaker is fuct on my phone)
or call work phone on 8258 0796 and ask for Shane
Ill bring it with me to work
Hey,
I'm after a R32 GTR spoiler (will swap lip type if keen).
Also after RB26 coilpack cover.
Send me a PM.
Cheers.
Edit:
Just after the spoiler and coilpack cover (not swapping the lip).
Thanks
make some offers guys, want stuff GONESKIS!
Set of 4x 16x7 polished mesh wheels with centre caps. Multi 4 and 5 stud x 114.3
$350 ONO
Black drift button
$10
Tomei hicas lock relay(plug in under parcel shelf (i think)to cancel any electrical for hicas)$20
Brand new 2 1/4" Exhaust Y peice + stainless 2" piping. was going to use for straight pipes. $50
R200 Longnose Hr31 diff, welded centre, 3:4 auto ratio, comes with half shafts (1 is snapped)
$100!!
FET turbo timer with HR31 wiring harness.
$30
R32 Series 2 Dash cluster+ Brand New R32 speedo cable
Excellent condition low km's (85578kms) series 2 (grey dials) dash
+brand new Genuine Nissan speedo cable (very commonly break/fault in r32s)
$180 ono (may seperate if i have a buyer for both)
SMS/ Ring me on 0431 320 803.
Cheers, Reece
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
    • Yeah, so try to post images with extensions that the internet can handle, not HEIC files which only arstyphones can handle.
    • I have two questions here, The first is regarding the harness attached to the power window and central locking control on the drivers door. I can't understand why the previous owner would join these wires together on the harness and why they did such a shit job. There was a wire with 10v hanging in the open un insulated. The OEM remote control works just fine The second is regarding the blue, green wire attached to what I believe is the lock actuator? These were running to the old immobiliser connected to the 'UNLOCK - COM' and 'LOCK - COM' wires. I imagine COM means communication and they just send a signal to the immobiliser whether the car is locked/unlocked?  IMG_9032.HEIC IMG_9037.HEIC IMG_9038.HEIC IMG_9041.HEIC
    • A name I haven't seen in a while, welcome back. Nothing much has changed, we are all still deluded Nissan owners.
