Wanted To Buy
Cubes
i got a working cas. $50 and its yours..
Where abouts are you located, I have no car so if its say 25km within 5039 (edwardstown) I can come get it on bike, otherwise can you deliver? lol
I am pretty desperate so like to get it tomorrow if that is possible?
Edited by Rolls
Items:
im looking to buy either a 32,33,34 in good condition.
Extra Info:
not looking to pay heaps but after a decent car.
Contact Details:
Pm
Price and price conditions:
under 10k if possible.
cheers sam
i have a very clean, very smart, very reliable r34 forsale - $13k
Items:
Extra Info:
Contact Details:
Pm
cheers sam
I know of a very very sweet/quick white 33 for sale for 14500.
one of the cleanest in adelaide
mike
Need a R33 (or maybe Z32, R34, Stagea, GTR perhaps?) tailshaft yoke or tailshaft. Putting a R33 RB25DET gearbox in my S14 and need a tailshaft or yoke to modify to fit. PM me if you have anything. :)
Edited by subliminal
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
