Need a few parts for clearing a defect etc, so cheaper the better. Car in question is an r32 gtst, however some rb25 parts will interchange so let me know what u have :)
Flywheel
Clutch - can be a stocker
Gearbox - rb20
tail shaft
Diff
Shockers with std height springs that don't leak etc
Rb20 Afm
Rb20 stocker exhaust or one that's 2.5" and quiet
If I can think of anymore I'll update.
Cheers
Currently chasing a few things.
- R33 stock springs either coupe or 4dr as long as stock
- R33 glovebox
- R33 Steering wheel (must be near mint no rips or sun damage etc) and must be non- airbag s/wheel
- R33 4dr driver's door power window amplifier (R32 4dr may be same)
PM me if you have any. Cheers.
Edited by RBT025
After a couple of bits for my R32 GTR..
Looking for a good clean R32 GTR drivers seat
Stock suspension
I may consider trading replacement parts for them.
RS-R coilovers that may need a reco
Recaro Seat
If you have either of these... or know a shop that has them.
Let me know!
Travis
Stock suspension
Tried to PM you on Suspension
You cannot recieve any new PM's is what I have been told by the board ;P
PM me when you've cleared your inbox out
-D
Flywheel
Gearbox - rb20
tail shaft
Diff
Rb20 Afm
updated list above in quote. Thanks for all the offers so far, much appreciated. Wouldnt be able to get the line back working without the help.
Edited by Bl4cK32
need the spacers that are used on exhaust manifold on rb25/20
there a thick round washer. after 2 of them!
pick up asap!
pretty sure i have some somewhere.
im also after a rb20 cas and rb20 tps
pm me as not in wtb section much.
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
