Wanted To Buy
Cubes
Needed ASAP 2 Nissan Bluebird rims/tyres... 1984 model.
i got rims here im pretty sure u can have. not sure about tires tho
or i have a set of 180 rims for sale. 15's
NEED the following for an r32 gtst:
Drivers 1/4 panel - black preferred, in exc. cond.
got a front guard drivers side, r32 in black here
got a small dent tho.
$20
std exhaust to get through regency
r32 gtst std diff
rb20 engine mounts - the metal brackets, not the rubber mounts
r32 gtst headlights in good nick (no cracks, broken mounts etc)
Let me know how much etc,
cheers.
door / panel sorted, still interested in the above.
Edited by Bl4cK32
hey ppls, im after a metal lathe. not fussed on brand, but would like atleast a 250mm head with a 400mm+ between centres.
thanks
mike
wanting to buy a few body parts for r33 s1
boot lid without spoiler (patched holes) black if possible
drift wing- black if possible
s1 aftermarket front bar -trial, top secret, nismo 400r (possibly black)
set of aftermarket coilovers in good working order for r33 gtst
will pay cash according to condition of items
text or pm
0413863525
Edited by FUTUREJDM33
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
